Hi.
After latest update microphone not working any more
ystem: Kernel: 5.12.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=84067dcd-be77-4d39-86b1-f126e0679937
systemd.unified_cgroup_hierarchy=1 resume=UUID=49e85462-2bd1-4bf2-9435-0625f255780f loglevel=3
Desktop: KDE Plasma 5.22.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: S500CA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: S500CA v: 1.0 serial: <filter> UEFI: American Megatrends v: S500CA.204
date: 02/05/2013
Battery: ID-1: BAT0 charge: N/A condition: N/A volts: N/A model: N/A type: Unknown serial: N/A
status: Unknown cycles: -1
CPU: Info: Dual Core model: Intel Core i5-3317U bits: 64 type: MT MCP arch: Ivy Bridge family: 6
model-id: 3A (58) stepping: 9 microcode: 21 cache: L2: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 13568
Speed: 1984 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 1984 2: 1513 3: 1474 4: 2132
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Realtek USB Camera type: USB driver: uvcvideo bus-ID: 1-1.2:4 chip-ID: 0bda:5705
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 21.1.3 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
Sound Server-1: ALSA v: k5.12.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.30 running: yes
Network: Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: AzureWave driver: ath9k
v: kernel port: f040 bus-ID: 02:00.0 chip-ID: 168c:0032 class-ID: 0280
Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: ASUSTeK driver: alx v: kernel
port: e000 bus-ID: 03:00.0 chip-ID: 1969:1091 class-ID: 0200
Bluetooth: Device-1: IMC Networks Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-1.1:3 chip-ID: 13d3:3402 class-ID: e001 serial: <filter>
Drives: Local Storage: total: 245.94 GiB used: 90.7 GiB (36.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Gigabyte model: GP-GSTFS31240GNTD size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: P1.3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD U100 24GB size: 22.37 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 6.02
Partition: ID-1: / raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 90.7 GiB (42.3%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 90.7 GiB (42.3%) fs: btrfs
ID-4: /var/log raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 90.7 GiB (42.3%) fs: btrfs
ID-5: /var/tmp raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 90.7 GiB (42.3%) fs: btrfs
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
Sensors: System Temperatures: cpu: 52.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3400
Info: Processes: 228 Uptime: 3m wakeups: 1 Memory: 7.65 GiB used: 2.1 GiB (27.4%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1498 lib: 354
Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04
Any solution .......
im no expert at all on this, but it seem like this should be running.
have you looked into pulseaudio -h
one option listed is pulseaudio --start
i would try to start it and if its not working you could always run pulseaudio --kill
to kill the running daemon.
this is my inxi -Faz
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
Sound Server-4: PipeWire v: 0.3.30 running: no
hope this helps
arco
22 June 2021 14:55
#3
Pulseaudio not running dosen't seem like a problem because pipewire is running. Isn't pipewire meant as a replacement for pulseaudio?
from what i read, PipeWire is another replacement for pulseaudio,,
PipeWire is a new low-level multimedia framework. It aims to offer capture and playback for both audio and video with minimal latency and support for PulseAudio , JACK , ALSA and GStreamer -based applications.
there is also a section on the Wiki about how to get Microphone Detection working
Thanks for your replay but the issue remain the same
When i try to start pulse then the resaults is:
pulseaudio --start
pulseaudio may be found in the following packages:
extra/pulseaudio 14.2-3 /usr/bin/pulseaudio
Thanks
arco
23 June 2021 17:51
#6
That means you don't have pulseaudio
installed.
(SOLVED)
Thank you.
I try to install the pulse from Garuda assistant but for some reason untick the pulse. So i try to install from add/remove and now it's working fine.
╰─λ inxi -Fxxxza
System: Kernel: 5.12.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.22.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
date: 02/05/2013
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 13569
Speed: 1517 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 1517 2: 2429 3: 2394 4: 1788
direct render: Yes
Drives: Local Storage: total: 245.94 GiB used: 91.09 GiB (37.0%)
Partition: ID-1: / raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 91.09 GiB (42.5%) fs: btrfs
ID-3: /home raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 91.09 GiB (42.5%) fs: btrfs
ID-4: /var/log raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 91.09 GiB (42.5%)
ID-5: /var/tmp raw-size: 214.52 GiB size: 214.52 GiB (100.00%) used: 91.09 GiB (42.5%)
maj-min: 8:3
ID-3: swap-3 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 63.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3700
Info: Processes: 224 Uptime: 1m wakeups: 1 Memory: 7.65 GiB used: 2.09 GiB (27.3%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1487 lib: 354
Thank you one more time.
great news! dont forget to mark solved
system
closed
25 June 2021 19:50
#9
