```text
System: Kernel: 5.15.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b535843d-ee6e-4bda-ae28-a47360553dcf rw rootflags=subvol=@ quiet splash
Desktop: GNOME 41.1 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0 Distro: Garuda Linux
Machine: Type: Laptop System: LENOVO product: 82C6 v: Lenovo V14-ADA
serial: <superuser required> Chassis: type: 10 v: Lenovo V14-ADA
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required> UEFI: LENOVO
v: E8CN27WW date: 01/15/2021
Battery: ID-1: BAT0 charge: 28.1 Wh (91.5%) condition: 30.7/30.0 Wh (102.3%) volts: 8.7 min: 7.5
model: SMP L16M2PB1 type: Li-poly serial: <filter> status: Charging cycles: 139
CPU: Info: Dual Core model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108109 cache:
L1: 192 KiB L2: 1024 KiB L3: 4 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 20760
Speed: 1816 MHz min/max: 1400/2600 MHz boost: enabled Core speeds (MHz): 1: 2526
2: 2484 3: 2695 4: 2701
Graphics: Device-1: AMD Picasso vendor: Lenovo driver: amdgpu v: kernel bus-ID: 02:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-5:2
chip-ID: 04f2:b624 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.1 compositor: gnome-shell driver: loaded: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa display-ID: :1 screens: 1
s-diag: 414mm (16.3")
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 112 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL:
renderer: AMD Radeon Vega 3 Graphics (RAVEN2 DRM 3.42.0 5.15.5-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 02:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x,snd_pci_acp5x
bus-ID: 02:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 02:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.5-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Lenovo
driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 2000 bus-ID: 01:00.0
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-6:3
chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 4 state: up address: <filter>
Drives: Local Storage: total: 931.51 GiB used: 13.22 GiB (1.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
serial: <filter> rev: LFM3 scheme: GPT
Partition: ID-1: / raw-size: 128 GiB size: 128 GiB (100.00%) used: 13.22 GiB (10.3%) fs: btrfs
dev: /dev/sda6 maj-min: 8:6
ID-2: /boot/efi raw-size: 1023 MiB size: 1021 MiB (99.80%) used: 580 KiB (0.1%)
fs: vfat dev: /dev/sda5 maj-min: 8:5
ID-3: /home raw-size: 128 GiB size: 128 GiB (100.00%) used: 13.22 GiB (10.3%) fs: btrfs
ID-4: /var/log raw-size: 128 GiB size: 128 GiB (100.00%) used: 13.22 GiB (10.3%)
fs: btrfs dev: /dev/sda6 maj-min: 8:6
ID-5: /var/tmp raw-size: 128 GiB size: 128 GiB (100.00%) used: 13.22 GiB (10.3%)
ID-1: swap-1 type: zram size: 3.28 GiB used: 1.77 GiB (53.9%) priority: 100
Sensors: Message: No sensor data found. Is lm-sensors configured?
Info: Processes: 256 Uptime: 4h 51m wakeups: 767 Memory: 3.28 GiB used: 2.46 GiB (75.0%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages:
pacman: 1119 lib: 297 Client: Unknown Client: garuda-assistant inxi: 3.3.09
I have started using Garuda Gnome version recently. It has been just 2 days and the thing that is happening is "Low Memory' warning message is often showing up. Yet i have not installed/downloaded much software or apps then also much memory space is already used (my laptop has 4gb ram). Also when i run more than two things in one desktop it starts to lag a little bit.
