Hey folks,
I came back to my desktop this morning to get to work, and I noticed that KDE left me some pop-up notifications that there was a memory shortage, and it killed some background services. The thing is, I have 32gb of memory, and I only had chrome running with 5 tabs open. It killed localsearch-3.service, plasma-powerdevil.service, and plasma-polkit-agent.service. I took a screenshot of the notifications:
Here’s my inxi:
> garuda-inxi
Kernel: 6.16.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=8dcc0c9c-8fe9-4fc6-b189-a8db2cfa3823 rw rootflags=subvol=@
rd.driver.pre=vfio-pci intel_iommu=on i915.enable_guc=3 i915.max_vfs=7
i915.force_probe=!4680 xe.force_probe=4680 quiet
resume=UUID=a14a443b-9c6b-47d0-b49a-d9686d767b7c loglevel=3
sysrq_always_enabled=1 split_lock_detect=off nvidia-drm.modeset=1
pci=disable_acs_redir=pci:12D8:2308
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0
Mobo: ASUSTeK model: PRIME Z690-P WIFI v: Rev 1.xx
UEFI: American Megatrends v: 3801 date: 05/14/2025
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
Info: model: 12th Gen Intel Core i9-12900K bits: 64 type: MST AMCP
microcode: 0x3A
Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2
st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32
KiB, 8x64 KiB L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB
desc: 1x30 MiB
Speed (MHz): avg: 800 min/max: 800/5100:5200:3900 scaling:
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 bogomips: 152985
Device-1: Intel AlderLake-S GT1 vendor: ASUSTeK driver: xe v: kernel
alternate: i915 arch: Xe process: Intel 10nm built: 2020-21 ports:
active: none empty: DP-4,HDMI-A-3,HDMI-A-4 bus-ID: 00:02.0
chip-ID: 8086:4680 class-ID: 0300
Device-2: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate]
vendor: ASUSTeK driver: nvidia v: 580.76.05 alternate: nouveau,nvidia_drm
gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: none off: DP-1,DP-3 empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 01:00.0
chip-ID: 10de:2489 class-ID: 0300
Device-3: Microsoft LifeCam Studio
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:4 chip-ID: 045e:0772
gpu: nv_platform,nvidia,nvidia-nvswitch d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-1 pos: primary,left model: Samsung SyncMaster
serial: <filter> built: 2009 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73") diag: 609mm (24")
Monitor-2: DP-3 pos: right model: Dell UZ2715H serial: <filter>
built: 2014 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 83 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 676mm (26.6") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.76.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
API: Vulkan v: 1.4.321 layers: 17 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: nvidia v: 580.76.05 device-ID: 10de:2489
surfaces: N/A device: 1 type: integrated-gpu name: Intel UHD Graphics 770
(ADL-S GT1) driver: mesa intel v: 25.2.1-arch1.5 device-ID: 8086:4680
surfaces: N/A device: 2 type: cpu name: llvmpipe (LLVM 20.1.8 256 bits)
driver: mesa llvmpipe v: 25.2.1-arch1.5 (LLVM 20.1.8)
de: kscreen-console,kscreen-doctor gpu: corectrl, gputop, intel_gpu_top,
lsgpu, nvidia-settings, nvidia-smi wl: wayland-info,wlr-randr
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: vfio-pci
alternate: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl bus-ID: 00:1f.3
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
API: ALSA v: k6.16.4-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0
IF-ID-1: br-1f7862558da6 state: down mac: <filter>
IF-ID-2: br-7bfc84ea431e state: down mac: <filter>
IF-ID-3: br-82d31aa0b51e state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-4: br-8cfdb6073e28 state: down mac: <filter>
IF-ID-5: br-960c3623af4c state: down mac: <filter>
IF-ID-6: br-b787944b7593 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-7: br-b90412b2529c state: down mac: <filter>
IF-ID-8: br-c3a5729d4cf6 state: down mac: <filter>
IF-ID-9: br-d7347e1a61c0 state: down mac: <filter>
IF-ID-10: br-e0cf0c4bc03a state: down mac: <filter>
IF-ID-11: br-e9c38ec2b98c state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-12: docker0 state: down mac: <filter>
IF-ID-13: powehi state: unknown speed: N/A duplex: N/A mac: N/A
IF-ID-14: veth27b186c state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-15: veth436f914 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-16: veth5d9218c state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-17: virbr0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0026
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 6.37 TiB used: 3.08 TiB (48.4%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 38.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO with
Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7
temp: 45.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000NE001-2MA101
tech: HDD rpm: 7200 serial: <filter> fw-rev: EN01 scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 815.3 GiB (44.6%)
fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p2 maj-min: 259:3
used: 620 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:2
used: 815.3 GiB (44.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p2
maj-min: 259:3
maj-min: 259:3
maj-min: 259:3
ID-1: swap-1 type: zram size: 31.08 GiB used: 5.15 GiB (16.6%)
ID-2: swap-2 type: partition size: 34.2 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:4
System Temperatures: cpu: 42.0 C mobo: N/A
Memory: total: 32 GiB note: est. available: 31.08 GiB used: 9.51 GiB (30.6%)
Processes: 709 Power: uptime: 1d 12m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.37 GiB services: org_kde_powerdevil,
Packages: 2687 pm: pacman pkgs: 2674 libs: 615 tools: octopi,pacseek,paru
pm: flatpak pkgs: 13 Compilers: clang: 20.1.8 gcc: 15.2.1 alt: 13/14
Shell: Bash v: 5.3.3 default: fish v: 4.0.2 running-in: kitty inxi: 3.3.38
Garuda (2.8.2-2):
System install date: 2024-10-16
Last full system update: 2025-09-02
22/23 checks run in 0.58 seconds ⌛
Powered by garuda-health 🦅
Even when I have chrome and firedragon running, along with Baldur’s Gate 3 - memory rarely goes over 60% usage. This seems unusual that memory would be used up - overnight - with only chrome running with 5 tabs. Anything I can do to troubleshoot this further to garner more information and find out what’s going on?
