Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=0b94ce5d-d009-4332-bc02-3fada2edb47c rw [email protected]
resume=UUID=85344af1-a402-4e3a-9a67-f0d7d08c8d75 loglevel=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
Mobo: ASUSTeK model: PRIME B560M-K v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1203
date: 10/27/2021
Info: model: Intel Core i5-10400F bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 3 microcode: 0xEC
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4000 high: 4001 min/max: 800/4300 scaling:
driver: intel_pstate governor: performance cores: 1: 4000 2: 4001 3: 4000
4: 4000 5: 4000 6: 4000 7: 4000 8: 4001 9: 4000 10: 4000 11: 4000
12: 4000 bogomips: 69597
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: ASUSTeK
driver: nvidia v: 510.68.02 alternate: nouveau,nvidia_drm pcie: gen: 2
speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:2187 class-ID: 0300
Screen-1: 0 s-res: 3840x1165 s-dpi: 96 s-size: 1016x308mm (40.00x12.13")
s-diag: 1062mm (41.8")
Monitor-1: DP-1 pos: primary,top-left res: 1920x1080 hz: 60 dpi: 305
size: 160x90mm (6.3x3.54") diag: 184mm (7.23") modes: N/A
Monitor-2: DVI-D-0 pos: primary,bottom-r res: 1920x1080 dpi: 102
size: 480x270mm (18.9x10.63") diag: 551mm (21.68") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1650 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 510.68.02 direct render: Yes
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
Device-3: BEHRINGER GmbH UMC202HD 192k type: USB driver: snd-usb-audio
bus-ID: 1-4:6 chip-ID: 1397:0507 class-ID: 0102 serial: <filter>
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fa class-ID: 0200
Device-2: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS] type: USB
driver: r8188eu bus-ID: 1-14:5 chip-ID: 2357:010c class-ID: 0000
IF: wlp0s20f0u14 state: up mac: <filter>
Local Storage: total: 2.95 TiB used: 1.61 TiB (54.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT480BX500SSD1
type: SSD serial: <filter> rev: 041 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT120BX300SSD1
size: 111.79 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 010 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD6400AAKS-22A7B2 size: 596.17 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 3B01
scheme: MBR
ID-1: / raw-size: 91.71 GiB size: 91.71 GiB (100.00%)
used: 19.35 GiB (21.1%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
used: 576 KiB (0.2%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 91.71 GiB size: 91.71 GiB (100.00%)
ID-4: /var/log raw-size: 91.71 GiB size: 91.71 GiB (100.00%)
ID-5: /var/tmp raw-size: 91.71 GiB size: 91.71 GiB (100.00%)
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda6 maj-min: 8:6
ID-2: swap-2 type: zram size: 15.48 GiB used: 40.2 MiB (0.3%)
System Temperatures: cpu: 59.0 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 24%
Processes: 322 Uptime: 1h 51m wakeups: 0 Memory: 15.48 GiB
used: 6.1 GiB (39.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1870 lib: 524 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-05-04
Last full system update: 2022-05-04 ↻
Welcome!
Thanks you
