Since the latest Iso of Garuda the program Mediathekview don't work, when I tried to start the program in konsole I get this error: "/usr/bin/mediathekview: line 5: java: command don't exist". How can I fix this?
I tried the program in Reborn Linux KDE and it work there.
No, but I have these: "java-enviroment-common version 3-3, java-openjdk-ea-bin version 17b16-1, java-openjfx version 16.u8-1" all of these together with Mediathekview got installed with octopi. I tried before that to install with bau but then no java files got installed.
i can´t help u to fix but u can use the app image that works for me . if u want too u can find there https://mediathekview.de/download/
with the installed version i had too problems .
it has work long time at me but last when i started i have also problems . i think medithekview need an update .
This is what i get in terminal :
mediathekview
Fehler: Beim Laden der Klasse mediathek.Main ist ein LinkageError aufgetreten
java.lang.UnsupportedClassVersionError: mediathek/Main (class file version 59.65535) was compiled with
preview features that are unsupported. This version of the Java Runtime only recognizes preview features for
class file version 60.65535
Btw, I think that you should bring this to notice of the developers, so that they can solve the issue for all, I guess it might be a universal issue for all Arch users.
