Media autoplays when earphone connected
I've recently noticed that whenever my earphones are connected to my laptop...
Whatever media(audio/video) is paused in the background, resumes playing automatically...
If I try to pause it...It automatically resumes to play again...
The only way to stop it from autoplaying again is disconnecting the earphones...
I had not noticed such behaviour when I had installed the OS...
For now, I have observed this to happen on Spotify, MPV player for audio and YouTube, KhanAcademy for video...
My System Specs(from Garuda Assistant)
System:    Kernel: 5.10.61-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
           root=UUID=59a5503e-fcee-4e1c-8787-e3f6172b5eaa rw [email protected] quiet splash
           Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Laptop System: LENOVO product: 80XH v: Lenovo ideapad 320-15ISK serial: <filter>
           Chassis: type: 10 v: Lenovo ideapad 320-15ISK serial: <filter>
           Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI-[Legacy]: LENOVO
           v: 4WCN37WW date: 12/04/2017
Battery:   ID-1: BAT0 charge: 15.4 Wh (75.5%) condition: 20.4/30.0 Wh (68.0%) volts: 7.6 min: 7.4
           model: LGC L16L2PB2 type: Li-poly serial: <filter> status: Discharging
CPU:       Info: Dual Core model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake
           family: 6 model-id: 4E (78) stepping: 3 microcode: EA cache: L2: 3 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 15999
           Speed: 2000 MHz min/max: 400/2000 MHz Core speeds (MHz): 1: 2000 2: 2000 3: 2000
           4: 2000
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP:
           conditional, RSB filling
Graphics:  Device-1: Intel HD Graphics 520 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
           chip-ID: 8086:1921 class-ID: 0300
           Device-2: Syntek EasyCamera type: USB driver: uvcvideo bus-ID: 1-8:3 chip-ID: 174f:241a
           class-ID: 0e02
           Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
           s-diag: 582mm (22.9")
           Monitor-1: eDP1 res: 1920x1080 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
           OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.2.1
           direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel
           v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
           Sound Server-1: ALSA v: k5.10.61-1-lts running: yes
           Sound Server-5: PipeWire v: 0.3.34 running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
           driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
           Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi v: kernel
           port: 3000 bus-ID: 02:00.0 chip-ID: 8086:3166 class-ID: 0280
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8
           bus-ID: 1-7:2 chip-ID: 8087:0a2a class-ID: e001
           Report: bt-adapter ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
           rfk-block: hardware: no software: no address: <filter>
Drives:    Local Storage: total: 931.51 GiB used: 41.75 GiB (4.5%)
           ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-24Z10T0
           size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
           rpm: 5400 serial: <filter> rev: 1A01 scheme: MBR
Partition: ID-1: / raw-size: 589.23 GiB size: 589.23 GiB (100.00%) used: 41.75 GiB (7.1%)
           fs: btrfs dev: /dev/sda4 maj-min: 8:4
           ID-2: /home raw-size: 589.23 GiB size: 589.23 GiB (100.00%) used: 41.75 GiB (7.1%)
           ID-3: /var/log raw-size: 589.23 GiB size: 589.23 GiB (100.00%) used: 41.75 GiB (7.1%)
           ID-4: /var/tmp raw-size: 589.23 GiB size: 589.23 GiB (100.00%) used: 41.75 GiB (7.1%)
           ID-1: swap-1 type: zram size: 7.56 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 36.5 C mobo: N/A
Info:      Processes: 221 Uptime: 31m wakeups: 31354 Memory: 7.56 GiB used: 3.22 GiB (42.6%)
           Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
           pacman: 1502 lib: 345 Client: Unknown Client: garuda-assistant inxi: 3.3.06
What sort of earphones are you referring to?
Does it have built-in media control buttons? (play/pause etc.)
Yes it does have those...
But I have ensured that nobody is touching them...
I use them with my phone as well...haven't observed the absurd behaviour...
Moreover, this problem didn't exist when i had just installed Garuda...
If this is something new, it must have been introduced by a recent update of eg pipewire or ALSA (this could be checked in var/log/pacman.log). For sure not in all the players.
If it is a new feature, maybe it has a setting to be disabled in the audio settings?
If it is a bug, I don't know, maybe you could switch to pulseaudio and try with it?
