Maxed resources?
Something strange is happening and I cant figure if out. Ive been playing Red Dead Redemption 2 for nearly 200 hours. Other than an occasional hick up. it has ran great/. At 10:00 this morming it was running great. Go to play it tonight and it immediately maxes out CPU usage to 99% slows down to 1-2 fps. and all tht is before i can get started on the game. which I'.ve dome everthing i iknow to short and slows down to 1-2 frames a second. Anyone ran in to this issue before? any help is appreciated
```text
  Kernel: 6.4.7-zen1-3-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=17d9134e-705b-401f-8855-87098b482bdf
    rw rootflags=subvol=@ quiet quiet rd.udev.log_priority=3 vt.global_cursor_default=0
    resume=UUID=4340d6ff-bc5f-4b71-8031-81bba7025333 loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Laptop System: HP product: HP Laptop 15-dy2xxx v: N/A serial: <superuser required> Chassis:
    type: 10 serial: <superuser required>
  Mobo: HP model: 87FE v: 57.20 serial: <superuser required> UEFI: AMI v: F.21 date: 03/21/2022
  ID-1: BAT0 charge: 39.7 Wh (100.0%) condition: 39.7/41.0 Wh (96.7%) volts: 12.9 min: 11.4
    model: HP Primary type: Li-ion serial: <filter> status: full cycles: 16
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP arch: Tiger Lake gen: core 11
    level: v4 note: check built: 2020 process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xAA
  Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 320 KiB
    desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 3000 min/max: 400/4200 scaling: driver: intel_pstate governor: performance
    cores: 1: 3000 2: 3000 3: 3000 4: 3000 5: 3000 6: 3000 7: 3000 8: 3000 bogomips: 38707
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Hewlett-Packard driver: i915
    v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: DP-1,
    DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Chicony HP TrueVision HD Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-3:4 chip-ID: 04f2:b6f1 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: BOE Display 0x0991 built: 2020 res: 1920x1080 hz: 60 dpi: 142
    gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.1.5 renderer: Mesa Intel Xe Graphics (TGL GT2) direct-render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel,snd_sof_pci_intel_tgl
    bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
  API: ALSA v: k6.4.7-zen1-3-zen status: kernel-api with: aoss type: oss-emulator
  Server-1: PipeWire v: 0.3.76 status: active with: 1: pipewire-pulse status: active
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
    driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 3000 bus-ID: 0000:01:00.0
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-10:6 chip-ID: 0bda:b00e class-ID: e001 serial: <filter>
  Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
    bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 1.36 TiB used: 717.58 GiB (51.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model:
 WD BLACK SN770 1TB
    serial: <filter> fw-rev: 731100WD temp: 37.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: PSSD T7 size: 465.76 GiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD
    serial: <filter> scheme: GPT
  ID-1: / raw-size: 39.06 GiB size: 39.06 GiB (100.00%) used: 14.29 GiB (36.6%) fs: btrfs
  ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%) used: 147.3 MiB (14.8%) fs: vfat
  ID-3: /home raw-size: 858.4 GiB size: 858.4 GiB (100.00%) used: 565.77 GiB (65.9%) fs: btrfs
  ID-4: /var/log raw-size: 39.06 GiB size: 39.06 GiB (100.00%) used: 14.29 GiB (36.6%) fs: btrfs
  ID-5: /var/tmp raw-size: 39.06 GiB size: 39.06 GiB (100.00%) used: 14.29 GiB (36.6%) fs: btrfs
  ID-1: swap-1 type: zram size: 15.27 GiB used: 15.2 GiB (99.5%) priority: 100 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 33.07 GiB used: 7.31 GiB (22.1%) priority: -2
  System Temperatures: cpu: 77.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0 fan-2: 0
  Processes: 312 Uptime: 58m wakeups: 2119 Memory: total: 16 GiB note: est. available: 15.27 GiB
  used: 7.22 GiB (47.2%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
  gcc: 13.2.1 Packages: 1871 pm: pacman pkgs: 1857 libs: 559 tools: octopi,pamac,paru,trizen
  pm: flatpak pkgs: 14 Client: shell wrapper v: 5.1.16-release inxi: 3.3.28
  System install date:     2023-08-04
  Last full system update: 2023-08-05 ↻
Check in a resource monitor like btop or htop to see what is holding down the CPU.
As far as I can tell, it's steam thats doing it but its not making any sense. There was no update that I'm aware of. I tried booting into a snapshot and it sent me directly to maintenance mode. Something happened. I was just hoping it had happened to someone else smarter than me who knew how to fix it. Here's a screenshot of HTop. It's Steam. Why its beating the hell out of core #6 I dont know. I'm afraid my knowledge of how it doles out the work to the different cores is nonexistant. I aint got that far yet.
You’re hoping another user has your problems? Have you tried a Google search on that?
Also, your system needs rebooting. See if that changes things.
Maybe you need to delete the related caches or configs because something got messed up there. It must be somekind of conflct or corrupted files, I think.
Other options.. Try different proton version.
Backup the important files first!
