Mate is running amazingly Beautiful and fast
  Kernel: 6.1.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=13aa3a7a-1113-4447-8543-65930ee32eba rw [email protected]
    loglevel=3 ibt=off
  Desktop: MATE v: 1.26.0 info: mate-panel wm: marco v: 1.26.1 vt: 7
    dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Mobo: ASUSTeK model: PRIME Z490-A v: Rev 1.xx serial: <superuser required>
    UEFI: American Megatrends v: 2601 date: 05/17/2022
  Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
    model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 3882 high: 5115 min/max: 800/5100 scaling:
    driver: intel_pstate governor: performance cores: 1: 3800 2: 3800 3: 3800
    4: 3800 5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800
    13: 5115 14: 3800 15: 3800 16: 3800 bogomips: 121596
    vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
    process: GF 14nm built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s ports: active: HDMI-A-1 empty: DP-1, DP-2,
    DVI-D-1, HDMI-A-2 bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
    temp: 50.0 C
  Display: x11 server: X.Org v: 21.1.6 compositor: marco v: 1.26.1 driver:
    X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    s-diag: 777mm (30.58")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: AOC Q32G1WG4 serial: <filter>
    built: 2019 res: 2560x1440 dpi: 93 gamma: 1.2 size: 697x393mm (27.44x15.47")
    diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
    missing.
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  Sound API: ALSA v: k6.1.9-zen1-1-zen running: yes
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3
  IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 3.18 TiB used: 1.14 TiB (35.7%)
    model: WDS250G2B0C-00PXH0 size: 232.89 GiB block-size: physical: 512 B
    rev: 211070WD temp: 37.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung
    rev: 2B2QEXM7 temp: 42.9 C
  ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD130 size: 2.73 TiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
    rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
    used: 16.73 GiB (7.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 48.0 C mobo: N/A gpu: amdgpu temp: 50.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1194
  Processes: 362 Uptime: 1h 4m wakeups: 0 Memory: 31.25 GiB
  used: 2.63 GiB (8.4%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1326
  libs: 334 tools: gnome-software,octopi,pamac,paru,yay Shell: Bash v: 5.1.16
  running-in: mate-terminal inxi: 3.3.24
Garuda (2.6.14-1):
  System install date:     2023-02-06
  Last full system update: 2023-02-06 ↻
Amazing i am in Love
very happy with with MATE
Hi there,
We are glad that you liked it.
See you around !
