I have been doing some research on cause of displays sleeping and waking or staying awake and failing to go back to sleep. Found evidence that kscreen has issues with multi-monitor, probably with different specs and connection types.
I disabled kscreen 2 and it seems to make things work as expected. However, it also means I have to configure my displays every time i restart. Is there a way to make my display configuration permanent in kde without kscreen?
Kernel: 5.18.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=eaa1f1c6-9940-4c37-9baf-9750aa94737c rw [email protected]
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Desktop Mobo: ASUSTeK model: MAXIMUS VIII HERO v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 3802
date: 03/15/2018
Info: model: Intel Core i7-7700K bits: 64 type: MT MCP arch: Kaby Lake
gen: core 7 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 9 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4693 high: 4700 min/max: 800/4700 scaling:
driver: intel_pstate governor: performance cores: 1: 4700 2: 4700 3: 4700
4: 4699 5: 4699 6: 4674 7: 4679 8: 4700 bogomips: 67200
Type: l1tf
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: XFX Speedster MERC 319 driver: amdgpu v: kernel arch: RDNA 2
lanes: 16 ports: active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 03:00.0
chip-ID: 1002:73bf class-ID: 0300
s-diag: 1245mm (49.01")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: primary,top-right
model: AOC AG271QG4 serial: <filter> built: 2016 res: 2560x1440 dpi: 109
gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-l model: AOC 2769M
serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
OpenGL: renderer: AMD Radeon RX 6800 XT (sienna_cichlid LLVM 14.0.6 DRM
3.46 5.18.10-zen1-1-zen)
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Sound Server-1: ALSA v: k5.18.10-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.54 running: yes
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-10:4 chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Local Storage: total: 23.41 TiB used: 5.43 TiB (23.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 1TB
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: RKT401.3
temp: 28.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Sabrent model: Rocket 4.0 1TB
temp: 31.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWE150 size: 4.55 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: FP2A scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST240HM000-1G5152
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: C675 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD40EZRX-00SPEB0 size: 3.64 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 3B6Q scheme: MBR
ID-7: /dev/sde maj-min: 8:64 type: USB vendor: Western Digital
model: WD easystore 264D size: 12.73 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 3012 scheme: GPT
used: 366.84 GiB (39.4%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:6
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5
ID-1: swap-1 type: zram size: 31.29 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 37.0 C mobo: N/A gpu: amdgpu temp: 32.0 C
mem: 34.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 988
Processes: 350 Uptime: 21m wakeups: 0 Memory: 31.29 GiB
used: 4.43 GiB (14.2%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 alt: 11 clang: 14.0.6 Packages:
pacman: 1855 lib: 526 Shell: fish v: 3.4.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-06-13
Last full system update: 2022-07-11
