Hello!
May I use makepkg tweaks from Archwiki without destroying my system?
The reason I'm asking is because my building/ complying time is very slow in C# written AUR packages.
Sysinfo
─λ inxi -Fxxxza
System: Kernel: 5.10.7-111-tkg-pds x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: intel_pstate=passive BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-pds-nehalem
root=UUID=3d6644cc-3196-4afd-a8d6-95fb20e38c4b rw rootflags=subvol=@ quiet splash
loglevel=3 rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine: Type: Laptop System: Hewlett-Packard product: HP EliteBook 8540p v: N/A
Mobo: Hewlett-Packard model: 1521 v: KBC Version 32.36 serial: <filter>
UEFI: Hewlett-Packard v: 68CVD Ver. F.60 date: 11/11/2015
Battery: ID-1: BAT0 charge: 57.4 Wh condition: 58.2/58.2 Wh (100%) volts: 16.3/14.4
model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: Unknown
CPU: Info: Quad Core model: Intel Core i7 Q 840 bits: 64 type: MT MCP arch: Nehalem
family: 6 model-id: 1E (30) stepping: 5 microcode: A L2 cache: 8 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 29828
Speed: 1661 MHz min/max: 1199/1867 MHz boost: enabled Core speeds (MHz): 1: 1661
2: 1655 3: 1315 4: 1731 5: 1293 6: 1904 7: 1262 8: 1811
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Graphics: Device-1: NVIDIA GF106GLM [Quadro 2000M] vendor: Hewlett-Packard driver: nvidia
v: 390.138 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:0dda
Device-2: Chicony HP Webcam [2 MP Macro] type: USB driver: uvcvideo bus ID: 1-1.5:5
chip ID: 04f2:b15e
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 102 s-size: 340x191mm (13.4x7.5")
s-diag: 390mm (15.4")
Monitor-1: LVDS-0 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Quadro 2000M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.138 direct render: Yes
Audio: Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:3b56
Device-2: NVIDIA GF106 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0be9
Sound Server: ALSA v: k5.10.7-111-tkg-pds
Network: Device-1: Intel 82577LM Gigabit Network vendor: Hewlett-Packard driver: e1000e
v: kernel port: 6020 bus ID: 00:19.0 chip ID: 8086:10ea
Device-2: Intel Centrino Advanced-N 6200 driver: iwlwifi v: kernel port: 5000
bus ID: 44:00.0 chip ID: 8086:4239
Drives: Local Storage: total: 931.51 GiB used: 33.93 GiB (3.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 023
Partition: ID-1: / raw size: 530.66 GiB size: 530.66 GiB (100.00%) used: 33.91 GiB (6.4%)
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 25.8 MiB (8.6%)
fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw size: 530.66 GiB size: 530.66 GiB (100.00%) used: 33.91 GiB (6.4%)
ID-4: /var/log raw size: 530.66 GiB size: 530.66 GiB (100.00%) used: 33.91 GiB (6.4%)
ID-5: /var/tmp raw size: 530.66 GiB size: 530.66 GiB (100.00%) used: 33.91 GiB (6.4%)
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 67.0 C mobo: 0.0 C gpu: nvidia temp: 59 C
Info: Processes: 270 Uptime: 6h 03m wakeups: 2 Memory: 7.65 GiB used: 4 GiB (52.3%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1597 lib: 490
Shell: fish v: 3.1.2 running in: alacritty inxi: 3.2.02
