Hello,
As I log in on a fresh install every desktop element is very small. To solve the problem I go on "session settings" (LXQT preferences) where I enter a scale factor of 2. Finally I reboot the system.
There are 2 resulting problems:
The scaling is not applied consistently. In other words not all the graphical desktop elements react to the setting. For example the LXQT menu and the LXQT lateral panel have the desired setting, however the log in screen does not. Same goes for the top "bar" of each window which remains small while the window's content is scaled properly (an exception here is the firedragon browser which applies the setting as expected)
The bottom bar (Latte) disappears after the scaling. I tried to disable autohide but could not find a menu item for setting the Latte bar.
Hope somebody can provide me with some hints/solution
Thank you!
Kernel: 5.19.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=ee7db7b3-1fe0-4d7c-81e0-f5de706aa80b rw rootflags=subvol=@
resume=UUID=1c399ee5-0dcd-4d5e-82a8-53abe8f1e808 loglevel=3
Desktop: LXQt v: 1.1.0 tk: Qt v: 5.15.6 info: cairo-dock, lxqt-panel
Type: Laptop System: Apple product: MacBookPro11,3 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-2BD1B31983FE1663
Mobo: Apple model: Mac-2BD1B31983FE1663 v: MacBookPro11,3
serial: <superuser required> UEFI: Apple v: 432.60.3.0.0 date: 10/27/2021
ID-1: BAT0 charge: 57.0 Wh (73.7%) condition: 77.3/95.4 Wh (81.1%)
volts: 12.6 min: 11.3 model: DP bq20z451 type: Li-ion serial: N/A
status: charging cycles: 1011
Info: model: Intel Core i7-4850HQ bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 built: 2013-15 process: Intel 22nm family: 6
model-id: 0x46 (70) stepping: 1 microcode: 0x1C
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1186 high: 2400 min/max: 800/3500 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 2295 3: 800
4: 800 5: 2400 6: 800 7: 800 8: 800 bogomips: 36716
vulnerable
Device-1: NVIDIA GK107M [GeForce GT 750M Mac Edition] vendor: Apple
driver: nouveau v: kernel non-free: series: 470.xx+
status: legacy-active (EOL~2023/24) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-18 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:0fe9
compositor: kwin_x11 driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 2880x1800 s-dpi: 96 s-size: 762x476mm (30.00x18.74")
s-diag: 898mm (35.37")
Monitor-1: eDP-1 model: Apple Color LCD built: 2013 res: 2880x1800 hz: 60
dpi: 221 gamma: 1.2 size: 331x207mm (13.03x8.15") diag: 390mm (15.4")
ratio: 16:10 modes: max: 2880x1800 min: 800x600
Device-1: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Device-2: NVIDIA GK107 HDMI Audio vendor: Apple driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14e4:1570 class-ID: 0480
Sound Server-1: ALSA v: k5.19.12-zen1-1-zen running: yes
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
bus-ID: 03:00.0 chip-ID: 14e4:43a0 class-ID: 0280
Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-8.3:6 chip-ID: 05ac:8289 class-ID: fe01
Local Storage: total: 465.92 GiB used: 12.36 GiB (2.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0512F
size: 465.92 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: JA1Q scheme: GPT
ID-1: / raw-size: 448.53 GiB size: 448.53 GiB (100.00%) used: 12.36 GiB
(2.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 448.53 GiB size: 448.53 GiB (100.00%) used: 12.36
GiB (2.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 448.53 GiB size: 448.53 GiB (100.00%) used: 12.36
ID-5: /var/tmp raw-size: 448.53 GiB size: 448.53 GiB (100.00%) used: 12.36
ID-2: swap-2 type: partition size: 17.09 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 71.0 C mobo: N/A gpu: nouveau temp: 65.0 C
Processes: 234 Uptime: 1h 18m wakeups: 7 Memory: 15.54 GiB used: 2.86 GiB
(18.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1155 libs: 307
running-in: qterminal inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-10-03
Last full system update: 2022-10-03 ↻
