Hello, when I use terminal "lutris --list-steam-games" lutris recognizes all the games that are installed on steam. But when using gui I am clicking the synchronize button. All of my Steam games show up but lutris does not recognize the installed ones on the gui. Everything looks uninstalled. How can I solve this problem?
Thanks.
Might be a question for the Lutris forum?
Maybe but before I switched to Garuda (yesterday) it was working fine. I thought it would be because of Garuda version of lutris. Because theming and places are different. Normally I would right-clik steam and click import-games but there is no option of this in Garuda version. How can I install normal themed lutris? It would probably solve my problem. I tried lutris-git version but theming stays the same.
There is no such thing as a “Garuda” version of Lutris, it’s the one available in Arch’s repositories which is getting installed. If its caused by a misconfiguration you might try deleting the configs of Lutris and starting the process again.
rm -r ~/.config/lutris
rm -r ~/.local/share/lutris
Okay I thought because of theming there is a Garuda version. My bad. I tried the remove configs, it didn’t work. Thanks for the help. I will try Lutris forums.
One good thing about Linux is theming! Since Lutris is GTK based it will of course look different if desktop theming is different.
Not just theming though, Lutris seems different because it got an update that I wasn't aware of. That is why I was also confused. Looking, syncing and some other settings were different.
