Is there a way to configure "ls" as it is by default displaying for "ls -la" I just want to give output for simple ls.
you can use dir instead of ls until this is solved. But dir gives me the feeling of windows and I hate windows, so I would also like to see the solution for this.
make in
.zshrc
alias ls='ls -la'
but IIRC it is inside in Garuda DE's
Its set in fish (~/.config/fish/config.fish)
In this well commented file you just need to remove the alias for ls
OMG, need coffee first.
# Automatically ls when changing directory
cd() {
builtin cd "$@" && ls --group-directories-first --time-style=+"%d.%m.%Y %H:%M" --color=auto
alias ls='ls --group-directories-first --time-style=+"%d.%m.%Y %H:%M" --color=auto'
alias li='ls --group-directories-first --time-style=+"%d.%m.%Y %H:%M" --color=auto -F'
alias grep='grep --colour=auto'
alias egrep='egrep --colour=auto'
alias fgrep='fgrep --colour=auto'
alias ll='ls -l |more'
alias la='ls -A |more'
with .zshrc
so for 'ls -la' type 'la'
For auto list, edit the top command - if I enter a directory (e.g. type 'Documents') then it goes quietly, but if I do 'cd Documents' then I get an instant listing.
My 'cd' is set to do 'ls' with directories first, but you could change that.
