Low rear sound on virtual surround
I have a SteelSeries Arctic 7 (7.1 virtual surround) on which I am trying to get the VS to work. I have tried various fixes I found in online forums but to no avail.
Some of them are working just fine, whilst others don't. Under is the output of speaker-test -c 8 -t wav:
speaker-test 1.2.4
Playback device is default
Stream parameters are 48000Hz, S16_LE, 8 channels
WAV file(s)
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 24 to 262144
Period size range from 8 to 87382
Using max buffer size 262144
Periods = 4
was set period_size = 65536
was set buffer_size = 262144
 0 - Front Left
 4 - Center
 1 - Front Right
 7 - Side Right
 3 - Rear Right
 2 - Rear Left
 6 - Side Left
 5 - LFE
0, 4, 1 - work fine
7, 3, 2, 6 - I can barely hear
5 - no sound
Can someone please help me?
Output of aplay -l
Output of aplay -L
This is the output of pacmd list-sinks
2 sink(s) available.
    index: 0
	driver: <module-alsa-card.c>
	flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 9040
	volume: mono: 65536 / 100% / 0,00 dB
	        balance 0,00
	base volume: 65536 / 100% / 0,00 dB
	volume steps: 65537
	muted: no
	current latency: 0,00 ms
	max request: 0 KiB
	max rewind: 0 KiB
	monitor source: 0
	sample spec: s16le 1ch 44100Hz
	channel map: mono
	             Mono
	used by: 0
	linked by: 0
	configured latency: 0,00 ms; range is 0,50 .. 2000,00 ms
	card: 1 <alsa_card.usb-SteelSeries_SteelSeries_Arctis_7-00>
	module: 7
	properties:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = "USB Audio"
		alsa.id = "USB Audio"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "0"
		alsa.card = "2"
		alsa.card_name = "SteelSeries Arctis 7"
		alsa.long_card_name = "SteelSeries SteelSeries Arctis 7 at usb-0000:00:14.0-8, full speed"
		alsa.driver_name = "snd_usb_audio"
		device.bus_path = "pci-0000:00:14.0-usb-0:8:1.0"
		sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/sound/card2"
		udev.id = "usb-SteelSeries_SteelSeries_Arctis_7-00"
		device.bus = "usb"
		device.vendor.id = "1038"
		device.vendor.name = "SteelSeries ApS"
		device.product.id = "12ad"
		device.product.name = "SteelSeries Arctis 7"
		device.serial = "SteelSeries_SteelSeries_Arctis_7"
		device.string = "hw:2,0,0"
		device.buffering.buffer_size = "176400"
		device.buffering.fragment_size = "88200"
		device.access_mode = "mmap+timer"
		device.profile.name = "mono-chat"
		device.profile.description = "Chat"
		device.intended_roles = "phone"
		device.description = "SteelSeries Arctis 7 Chat"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-usb"
	ports:
		usb-gaming-headset-output-mono: Headphones Mono Output (priority 0, latency offset 0 usec, available: unknown)
			properties:
	active port: <usb-gaming-headset-output-mono>
  * index: 1
	flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 9040
	volume: front-left: 65536 / 100% / 0,00 dB,   front-right: 65536 / 100% / 0,00 dB
	        balance 0,00
	volume steps: 65537
	muted: no
	max request: 0 KiB
	max rewind: 0 KiB
	monitor source: 1
	sample spec: s16le 2ch 48000Hz
	channel map: front-left,front-right
	             Stereo
	used by: 0
	linked by: 0
	configured latency: 0,00 ms; range is 0,50 .. 1837,50 ms
	module: 7
	properties:
		device.api = "alsa"
		alsa.name = "USB Audio #1"
		alsa.device = "1"
		alsa.card = "2"
		device.bus = "usb"
		device.string = "hw:2,1,0"
		device.buffering.buffer_size = "352800"
		device.buffering.fragment_size = "176400"
		device.profile.name = "stereo-game"
		device.profile.description = "Game"
		device.description = "SteelSeries Arctis 7 Game"
	ports:
		usb-gaming-headset-output-stereo: Headphones (priority 0, latency offset 0 usec, available: unknown)
			properties:
	active port: <usb-gaming-headset-output-stereo>
Hey, there @zeno. It's really hard to remotely debug someone's sound issues, especially when it's not an occurance that is seen regularly. You might get lucky and someone can offer advice, but I think you might just have to work through this as best you can.
Good luck.
I see. Well, I've tried some of the suggestions found on both the Arch Wiki and the Ubuntu forums, but none of it seemed to help. I guess I'll just have to cross my fingers and see if anyone's got a suggestion for me to try out.
The only suggestion I have is to see if the new updates to alsa help your situation too. There has been a lot of sound weirdness lately!
PS: There are some new updates today - and they have solved the troubles for more than one poster I have seen... I'll get back to you after I try MY issue again after the update :grin:
Edit: My trouble seem to be over - hope yours are too!
