when i installed garuda on my laptop, it was very smooth (while both plugged in and not plugged in) but after updating it for first time , it only works perfect when plugged in , otherwise it is very lagy and choppy.
please fix it so that i could recommend it to other people.
If you are hoping for a knowledgeable answer, you will need (at a minimum) information about the system you are running it on (terminal command inxi -Fxxxza, then paste the text output between sets of 3 backticks in the next message. It might also help to know what packages were updated. A section from /var/log/pacman.log - also posted between sets of backticks - will convey that information.
With that added to the next post, help may be possible.
I have exactly the same symptoms. When the power is disconnected, the system runs as if it were on hardware from twenty years ago. Sorry for the English (deepl.com/translator).
Kernel: 5.10.8-112-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: intel_pstate=passive
BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-bmq
root=UUID=ec47e905-39f5-4440-9fbb-003f6a0dcca7 rw rootflags=subvol=@
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Type: Laptop System: HP product: HP Laptop 15-da0xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10
Mobo: HP model: 84A7 v: 80.31 serial: <filter> UEFI: Insyde v: F.07
date: 11/21/2018
ID-1: BAT1 charge: 28.8 Wh condition: 28.8/41.9 Wh (69%)
volts: 13.0/11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Full
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142)
stepping: A (10) microcode: E0 L2 cache: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 28824
Speed: 2511 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 2511
2: 2551 3: 3400 4: 3400 5: 3370 6: 3402 7: 3402 8: 3401
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes,
SMT vulnerable
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:5917
Device-2: NVIDIA GM108M [GeForce MX110] vendor: Hewlett-Packard
driver: nvidia v: 460.32.03 alternate: nouveau,nvidia_drm
bus ID: 01:00.0 chip ID: 10de:174e
Device-3: Lite-On HP TrueVision HD Camera type: USB driver: uvcvideo
bus ID: 1-5:3 chip ID: 04ca:7092
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
driver: modesetting,nvidia display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: GeForce MX110/PCIe/SSE2 v: 4.6.0 NVIDIA 460.32.03
direct render: Yes
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.10.8-112-tkg-bmq
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000
bus ID: 02:00.0 chip ID: 10ec:8168
vendor: Hewlett-Packard driver: rtl8821ce v: N/A
modules: rtw88_8821ce,8821ce port: 3000 bus ID: 03:00.0
chip ID: 10ec:c821
v: 3.0 port: 6060 bus ID: 00:17.0 chip ID: 8086.282a rev: 21
Local Storage: total: 223.57 GiB used: 24.88 GiB (11.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSCKHF240A4L
size: 223.57 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: LSTi
ID-1: / raw size: 223.27 GiB size: 223.27 GiB (100.00%)
used: 24.88 GiB (11.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 560 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw size: 223.27 GiB size: 223.27 GiB (100.00%)
ID-4: /var/log raw size: 223.27 GiB size: 223.27 GiB (100.00%)
ID-5: /var/tmp raw size: 223.27 GiB size: 223.27 GiB (100.00%)
ID-1: swap-1 type: zram size: 731.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 731.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 731.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 731.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 731.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 731.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 731.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 731.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram7
System Temperatures: cpu: 55.5 C mobo: 29.8 C gpu: nvidia temp: 58 C
Processes: 269 Uptime: N/A wakeups: 1 Memory: 5.72 GiB
used: 1.9 GiB (33.2%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: pacman: 1668 lib: 455 Shell: Zsh v: 5.8 running in: konsole
inxi: 3.2.01
I don't know how to paste the system information correctly.
@3esky
Read Wiki Reporting Bugs
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
greetings SGS
Thanks and sorry. Next answer should be posted correctly.
I don't have a notebook but the nature of the matter is that I have an arrow-fast battery-based system, which will probably also run out of power very quickly.
status full, condition is bad 69% ???
IDK nothing about
So is the battery faulty?
IDK, read terminal output and check if the values are the same in conky or other tools.
Actually this happens due to auto-cpufreq
When on battery it sets powersave governor to increase battery life.
To disable this feature
You can disable the service
systemctl disable auto-cpufreq
Doing this and rebooting will set your governor to performance.
But it will reduce battery life.
Thank you very much. After executing the command in the terminal, the system runs just as fast without power as it does on power. Previously on a clean Arch system I did not observe such anomalies. Out of pure curiosity I will reinstall the system to Garuda Barebones KDE and check how the battery will behave without mains power (unless power saving in Garuda Linux is enabled by default). I don't know how it is with a pure Arch system (it will be tested as another - installed from a script: GitHub - MatMoul/archfi: Arch Linux Fast Installer : tutorial installer, GitHub - MatMoul/archdi: Arch Linux Desktop Installer : tutorial installer) - Arch Linux Desktop Install download | SourceForge.net,
Thank you so much. Really appreciated. Keep Helping.
I think there is a bug regarding auto-cpufreq.service.
After the first update my desktop run at lowest possible speed, but there is no battery to save!
So my first action after a fresh install of garuda is:
sudo systemctl disable auto-cpufreq.service
reboot
There after everything runs as expected.
I had the same issue, I disabled the 'auto-cpufreq.service' but the issue stays. I can see with cpupower that the cores are being scaled down and the governor is being changed to Powersave.
sudo systemctl status auto-cpufreq.service
auto-cpufreq.service - auto-cpufreq - Automatic CPU speed & power optimizer for Linux
Loaded: loaded (/usr/lib/systemd/system/auto-cpufreq.service; enabled; vendor preset: disabled)
Active: inactive (dead)
Then it is a different issue.
No system is the same. Start another topic, if you can’t solve it.
Welcome to Garuda!
