Kernel: 6.1.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=b00a8dfa-3c28-4653-9887-caa6a9240371 rw [email protected]
loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X470-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4011
date: 04/19/2018
Info: model: AMD Ryzen 7 1800X bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001137
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2335 high: 3600 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3600 2: 2200
3: 1819 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 2200 14: 3600 15: 1941 16: 2200 bogomips: 114969
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: CardExpert
driver: nvidia v: 525.78.01 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 08:00.0 chip-ID: 10de:1b06 class-ID: 0300
Device-2: Logitech C920 HD Pro Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-8.4:10 chip-ID: 046d:0892
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 107 s-size: 456x256mm (17.95x10.08")
s-diag: 523mm (20.59")
Monitor-1: DP-2 pos: primary size-res: N/A modes: N/A
Monitor-2: HDMI-0 res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.78.01 renderer: NVIDIA GeForce GTX 1080
Ti/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA GP102 HDMI Audio vendor: CardExpert driver: snd_hda_intel
v: kernel bus-ID: 1-5:2 chip-ID: 0d8c:016c pcie: gen: 3 class-ID: 0300
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 08:00.1
chip-ID: 10de:10ef class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
Device-3: C-Media USB Advanced Audio Device type: USB
Device-4: Kingston HyperX Cloud Alpha S type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-8.2:6 chip-ID: 0951:16ed
Device-5: Logitech C920 HD Pro Webcam type: USB
Sound API: ALSA v: k6.1.4-zen2-1-zen running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
Local Storage: total: 11.35 TiB used: 57.58 GiB (0.5%)
model: WDS240G2G0A-00JH30 size: 223.58 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DX002-2DV164
type: HDD rpm: 7200 serial: <filter> rev: CC41 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM006-2DM164
type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 type: USB vendor: Seagate
model: Backup+ Hub BK size: 5.46 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: D781 scheme: GPT
ID-6: /dev/sdf maj-min: 8:80 type: USB vendor: Western Digital
model: WD20EVDS-63T3B0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 2002 scheme: GPT
ID-1: / raw-size: 223.28 GiB size: 223.28 GiB (100.00%)
used: 23.5 GiB (10.5%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 608 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 223.28 GiB size: 223.28 GiB (100.00%)
ID-4: /var/log raw-size: 223.28 GiB size: 223.28 GiB (100.00%)
ID-5: /var/tmp raw-size: 223.28 GiB size: 223.28 GiB (100.00%)
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 52 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 330 Uptime: 20m wakeups: 0 Memory: 15.54 GiB
used: 2.81 GiB (18.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1211
libs: 314 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
Garuda (2.6.14-1):
System install date: 2022-12-19
Last full system update: 2023-01-11
Hello all. I have been using Garuda very Successfully for a couple of years now, but now I have encountered a very strange problem. I’ve got two monitors hooked up to my computer. The primary one is an Asus PQ 27 connected via DisplayPort to my graphics card. The secondary one is connected via the HDMI port and it’s a Samsung screen.
No, for some reason I have lost the output on the primary screen, well the secondary screen is functioning as normal, and and has taken the place of the primary screen as far as I can tell from xrandr.
When I start a system I can see the login screen and the splash screen on the display port screen but then the desktop completely fails to load Their end appears on the HDMI screen instead.
What’s More, it only seems to affect one particular user. I tried logging in on another user, and that one seems to work just as intended. This leads me to believe it’s probably some sort of software issue and that it should be correctable.
If possible I would like some suggestions on what files to look at and such to potentially solve the problem.
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 521mm x 293mm
1920x1080 60.00*+ 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 connected primary (normal left inverted right x axis y axis)
2560x1440 59.95 + 144.00 120.00 99.95 84.98 23.97
1024x768 60.00
800x600 60.32
640x480 59.94
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
