Hello.
inxi -Faz
System: Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=01964af9-f123-4b21-94bf-3a5143e0aa94 rw
[email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x serial: <filter> UEFI: American Megatrends
v: 3602 date: 03/05/2021
CPU: Info: 8-Core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 family: 19 (25) model-id: 21 (33)
stepping: 0 microcode: A201009 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 131207
Speed: 4100 MHz min/max: 2200/4100 MHz boost: enabled Core speeds (MHz): 1: 4100 2: 4100 3: 4100 4: 4100 5: 4098
6: 4100 7: 4100 8: 4099 9: 4100 10: 4099 11: 4100 12: 4100 13: 4100 14: 4100 15: 4100 16: 4099
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
Graphics: Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: ZOTAC driver: nvidia v: 470.74 alternate: nouveau,nvidia_drm
bus-ID: 0a:00.0 chip-ID: 10de:2482 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-1:2 chip-ID: 046d:082d
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 7680x2160 s-dpi: 162 s-size: 1204x341mm (47.4x13.4") s-diag: 1251mm (49.3")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 163 size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: DP-4 res: 3840x2160 hz: 60 dpi: 163 size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 470.74 direct render: Yes
Audio: Device-1: NVIDIA GA104 High Definition Audio vendor: ZOTAC driver: snd_hda_intel v: kernel bus-ID: 0a:00.1
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
Device-3: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-1:2 chip-ID: 046d:082d
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 05:00.0
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel port: d000 bus-ID: 06:00.0
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:3 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block: hardware: no software: no
address: <filter>
Drives: Local Storage: total: 1.36 TiB used: 31.81 GiB (2.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 613000WD temp: 44.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Smart Modular Tech. model: SHGS31-500GS-2 size: 465.76 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0Q00 scheme: GPT
Partition: ID-1: / raw-size: 465.75 GiB size: 465.75 GiB (100.00%) used: 31.79 GiB (6.8%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.5 MiB (26.6%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 465.75 GiB size: 465.75 GiB (100.00%) used: 31.79 GiB (6.8%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-4: /var/log raw-size: 465.75 GiB size: 465.75 GiB (100.00%) used: 31.79 GiB (6.8%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-5: /var/tmp raw-size: 465.75 GiB size: 465.75 GiB (100.00%) used: 31.79 GiB (6.8%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-1: swap-1 type: zram size: 62.71 GiB used: 2.8 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 38.5 C mobo: N/A gpu: nvidia temp: 48 C
Info: Processes: 403 Uptime: 6m wakeups: 0 Memory: 62.71 GiB used: 10.47 GiB (16.7%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1324 lib: 297 Shell: fish v: 3.3.1 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.08
Hi guys!
First of all, I would like to say that I am really enjoying Garuda linux Dragonized edition. I'm using it as one of the OS in my work machine. Everything has been working pretty smoothly until the recent wireplumber/pipewire changes. After applying the patches, for the past couple of days, at least 2 times each day, while I am working, all of a sudden my monitors (I have dual monitor setup) and my keyboard and mouse just lose connection to my PC. Following is what I have observed:
- This happens randomly, and there's no specific activity that I am doing when this happens. I have multiple IDEs and browser windows opened, but it has been like this since I have started using Garuda for my work.
- Reconnecting the peripherals, powering the monitors off and then back on, doesn't help either. Weird thing is that my PC is running normally.
- There are no changes to the Qcodes on the mobo as well. It's just that I can't use either my monitors or my keyboard and mouse.
- The only thing that I can do to resume normal work is to hard reset my PC. I am afraid that I will end up harming some components with these frequent hard resets, plus I also lose my work.
- Here's the output for today's journalctl for the system. PrivateBin. I have provided it because I experienced this issue in the morning today as well
Any help with regards to troubleshooting this issue, any guidance as to how I should start investigating this would be really appreciated. I am actually relying a lot on my Garuda installation and re-installing a different flavour of Garuda would be the very last resort that I would want to opt for. This is my first post so if any more information is required please let me know. Thanks in advance.
