Logseq-desktop permission denied
I installed logseq-desktop-0.9.3-1 from the choatic-aur.
sudo pacman -S loqseq-desktop The install went smoothly.
when I to run it from command line I get this error
logseq %u
/usr/bin/logseq: line 15: /opt/logseq-desktop/Logseq: Permission denied
line 15 of /usr/bin/logseq is:
exec /opt/logseq-desktop/Logseq $LOGSEQ_USER_FLAGS "[email protected]"
I can run logseq as sudo loqsec --no-sandbox in order to run. The app launches but the app is blank.
Kernel: 6.2.10-1-tt arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-tt
root=UUID=fee12699-5d85-4ddb-bae0-daf333cf53d5 rw [email protected]
loglevel=3 quiet splash ibt=off
Type: Laptop System: Micro-Star product: GL65 9SE v: REV:1.0
Mobo: Micro-Star model: MS-16U5 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16U5IMS.102 date: 03/17/2020
ID-1: BAT1 charge: 43.2 Wh (96.6%) condition: 44.7/51.6 Wh (86.6%)
volts: 11.9 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2540 high: 3686 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 801 2: 2600 3: 2600
4: 3686 5: 2600 6: 2600 7: 2600 8: 2600 9: 2600 10: 2600 11: 2600 12: 2600
bogomips: 62399
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
status: current (as of 2023-03) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:5
chip-ID: 04f2:b695 class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0xd0ed built: 2019 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.2.10-1-tt status: kernel-api with: aoss type: oss-emulator
tools: N/A
Server-1: PipeWire v: 0.3.69 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
driver: btusb v: 0.8 bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.38 TiB used: 858.23 GiB (60.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1032 size: 476.94 GiB block-size: physical: 512 B
rev: 20140000 temp: 36.9 C scheme: GPT
model: WD10JPVX-60JC3T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
used: 102.02 GiB (69.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-4: /var/log raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-5: /var/tmp raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.46 GiB used: 2.01 GiB (13.0%)
System Temperatures: cpu: 60.0 C pch: 42.0 C mobo: N/A
Processes: 454 Uptime: 8d 19h 23m wakeups: 61903 Memory: 15.47 GiB
used: 8.55 GiB (55.3%) Init: systemd v: 253 default: graphical
pkgs: 1791 libs: 505 tools: octopi,paru Shell: fish v: 3.6.1
System install date:     2022-07-14
Last full system update: 2023-04-18 ↻
Is partially upgraded:   Yes
Check if this comment helps:
https://aur.archlinux.org/packages/logseq-desktop#comment-908098
A reboot is also pending (just in case...).
just in case you don't follow links
sudo chmod o+rx /opt/logseq-desktop
