LoginError what should i do?
Hey fellas
I just updated my garuda after finished i reboot my laptop and then when i type my pass it says "login error"
Login screen also changed and in sure about my password. What the hell happened? I have a project to finish and im in hurry please help
Use last working snapshot, please, later you can chroot and fix Kernel problem or whatever.
Yup i restored it but how can i fix this? Somehow my password changed? Im kind of confused about what happened
You could launch garuda-update, not confirming the installation, and analyze which (to be) updated packages might influence this strange behaviour.
Maybe a keyboard layout change?
If you use special charachters in your password, you could change it to a very simple and numeric one and see how it goes after a new update.
Nah im not using keyboard layouts and my password is simple. Its just words
I think its better to do not update my garuda for a while
Its strange because my kdenlive is not working properly after i restored to last snap working :confused:
I am sorry to say this, but this topic is completely lacking in the typical information needed for minimal troubleshooting:
  • garuda-inxi is missing
  • we don't know which packages had been (would be, after the snapshot restore) updated
  • "Login screen also changed" is a bit vague
  • "kdenlive is not working properly" is a bit vague (and off-topic)
To get technical help (I am not a developer, but I see so many threads and know what technical people want...) you need precise, detailed information, error messages, logs, etc...
Yes my bad i should screen shot the login screen but i was in a hurry that time. but i restored it and login screen is the same before update.
  Kernel: 6.4.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=e159b6b8-0660-46f4-91d0-11782cc97f85
    rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
    loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Laptop System: ASUSTeK product: ROG Strix G733ZM_G733ZM v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: G733ZM v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC.
    v: G733ZM.311 date: 03/18/2022
  ID-1: BAT0 charge: 80.2 Wh (100.0%) condition: 80.2/90.0 Wh (89.1%) volts: 17.2 min: 15.9
    model: AS3GWAF3KC GA50358 type: Unknown serial: <filter> status: full
  Info: model: 12th Gen Intel Core i9-12900H bits: 64 type: MST AMCP arch: Alder Lake gen: core 12
    level: v3 note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154)
    stepping: 3 microcode: 0x42A
  Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled cache: L1: 1.2 MiB
    desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
    desc: 1x24 MiB
  Speed (MHz): avg: 2652 high: 4900 min/max: 400/4900:5000:3800 scaling: driver: intel_pstate
    governor: powersave cores: 1: 453 2: 2900 3: 3602 4: 4900 5: 4732 6: 2900 7: 400 8: 2900 9: 2900
    10: 2900 11: 400 12: 2900 13: 2900 14: 2900 15: 2900 16: 860 17: 2900 18: 2900 19: 2900
    20: 2900 bogomips: 116736
  Device-1: Intel Alder Lake-P Integrated Graphics vendor: ASUSTeK driver: i915 v: kernel
    arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports: active: eDP-1 empty: DP-1,DP-2
    bus-ID: 0000:00:02.0 chip-ID: 8086:46a6 class-ID: 0300
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK driver: nvidia
    v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+ status: current (as of 2023-05)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 bus-ID: 0000:01:00.0
    chip-ID: 10de:2520 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: iris gpu: i915
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: BOE Display 0x0a00 built: 2021 res: 1920x1080 hz: 360 dpi: 128
    gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.1.3 renderer: Mesa Intel Graphics (ADL GT2) direct-render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
  Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
    bus-ID: 0000:01:00.1 chip-ID: 10de:228e class-ID: 0403
  API: ALSA v: k6.4.1-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
  Server-1: PipeWire v: 0.3.72 status: active with: 1: pipewire-pulse status: active
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
    chip-ID: 8086:51f0 class-ID: 0280
  Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel port: 3000
    bus-ID: 0000:2c:00.0 chip-ID: 10ec:8125 class-ID: 0200
  IF: enp44s0 state: down mac: <filter>
  Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1
    bus-ID: 3-10:4 chip-ID: 8087:0033 class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-se
rvice: enabled,running rfk-block:
    bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
  Local Storage: total: 953.87 GiB used: 72.72 GiB (7.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00BTW size: 953.87 GiB
    fw-rev: GXA7401Q temp: 45.9 C scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 72.72 GiB (7.6%) fs: btrfs
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
  ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 72.72 GiB (7.6%) fs: btrfs
  ID-4: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 72.72 GiB (7.6%) fs: btrfs
  ID-5: /var/tmp raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 72.72 GiB (7.6%) fs: btrfs
  ID-1: swap-1 type: zram size: 15.28 GiB used: 12.5 MiB (0.1%) priority: 100 dev: /dev/zram0
  System Temperatures: cpu: 62.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  Processes: 378 Uptime: 35m wakeups: 2 Memory: available: 15.28 GiB used: 8.91 GiB (58.3%)
  Init: systemd v: 253 default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1565 libs: 450
  tools: gnome-software,octopi,pamac,paru Client: shell wrapper v: 5.1.16-release inxi: 3.3.27
  System install date:     2022-11-08
  Last full system update: 2023-07-04
  Failed units:            snap.v2ray-core.v2ray.service
