You read it right, black screen after reopening the lid after several mins, sometimes the display wont even show up after too many hours.
It is really annoying as I have to restart the whole laptop forcefully.
My laptop is HP Pavalion 15 Gaming axec026, with Garuda Linux Dragonized ediiton DUAL BOOTED WITH WINDOWS 10 ON SAME DISK Please assist me.
I'm not knowledgeable enough to properly troubleshoot this, but this might help:
https://wiki.archlinux.org/index.php/Power_management/Suspend_and_hibernate#Troubleshooting
I suggest you wait for someone experienced to answer, but if you want try something maybe enable early KMS for your Intel igpu.
You did not state whether this was the case since you installed, or if this is an older installation that this just started happening?
As you have been forum member 2 months now you should know how to post proper specs.
Post:
inxi -Fxxxxza
You should try changing your power states in your bios.
You should test a half dozen different kernels as this is your most likely fix.
Try at least these kernels:
linux-
linux-lts
linux-mainline
linux-zen
linux-next-git
linux-hardened
Post all your efforts and results.
Far more detailed specs are required at the minimum, and you need to answer all questions requested of you.
Is your bios up to date?
Please assist me (with this info).
My system Specs, I have tried linux-zen, but i doesnt help. Sorry for being this late
System: Kernel: 5.11.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=9d3fbaa9-9093-4c2e-8413-1a5d4cdf55ad
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec0xxx v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 86D4 v: 96.44 serial: <filter> UEFI: AMI v: F.12 date: 12/21/2020
Battery: ID-1: BAT0 charge: 42.9 Wh (100.0%) condition: 42.9/42.9 Wh (100.0%) volts: 12.8 min: 11.6
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Full cycles: 385
CPU: Info: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64 type: MT MCP
arch: Zen/Zen+ note: check family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108109
cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 33539
Speed: 1236 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1236 2: 1428
3: 1487 4: 1597 5: 2241 6: 1222 7: 1929 8: 1361
Graphics: Device-1: NVIDIA GP107M [GeForce GTX 1050 3 GB Max-Q] driver: nouveau v: kernel bus-ID: 01:00.0
chip-ID: 10de:1c91 class-ID: 0300
Device-2: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo bus-ID: 3-1:2
chip-ID: 0408:5365 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu,ati,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0 5.11.14-zen1-1-zen LLVM 11.1.0)
v: 4.6 Mesa 21.0.2 direct render: Yes
Audio: Device-1: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0fb9 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.11.14-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.25 running: no
Network: Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: e000 bus-ID: 03:00.0 chip-ID: 10ec:c822
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Report: ID: hci0 state: up address: <filter>
Drives: Local Storage: total: 1.14 TiB used: 40.42 GiB (3.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: AGHA4101 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter>
rev: RPM2 scheme: GPT
Partition: ID-1: / raw-size: 44.88 GiB size: 44.88 GiB (100.00%) used: 40.33 GiB (89.9%) fs: btrfs
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 88.4 MiB (34.5%) fs: vfat
ID-3: /home raw-size: 44.88 GiB size: 44.88 GiB (100.00%) used: 40.33 GiB (89.9%) fs: btrfs
ID-4: /var/log raw-size: 44.88 GiB size: 44.88 GiB (100.00%) used: 40.33 GiB (89.9%) fs: btrfs
ID-5: /var/tmp raw-size: 44.88 GiB size: 44.88 GiB (100.00%) used: 40.33 GiB (89.9%) fs: btrfs
ID-1: swap-1 type: zram size: 734.3 MiB used: 512 KiB (0.1%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 734.3 MiB used: 512 KiB (0.1%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 734.3 MiB used: 512 KiB (0.1%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 734.3 MiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 734.3 MiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 734.3 MiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 734.3 MiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 734.3 MiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 62.0 C mobo: N/A
GPU: device: nouveau temp: N/A device: amdgpu temp: 62.0 C
Info: Processes: 278 Uptime: 1h 38m wakeups: 1 Memory: 5.74 GiB used: 2.95 GiB (51.4%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 2068 lib: 564
Shell: fish v: 3.2.1 running-in: konsole inxi: 3.3.03
I update my BIOS few months ago. It switched on some settings which i disabled earlier like Secure Boot and turning on Legacy support.
What troubles me the most is my laptop doesn't go into hibernation. There's no option for it, still it switches off power automatically after certain time.
Kindly please suggest me method to change Linux kernel as previous change to Linux-zen was by my colleague
