Fresh install a few days ago. Noticed that when my monitor goes to sleep, I get two issues:
main monitor gets no signal. I have been able to work around it and fiddling with some settings (I think in the NVIDIA control app) I have been able to get the monitor to work again. I don't remember exactly what, but if needed, I can reproduce and document.
upon auto-logout after system idle, when trying to log back in on the screen provided, my password does not work; if I select "Other user" option, I get a different login screen (the "normal" one) and I can enter my password and the session login will start (Dragon icon with spinning circle around it), but after a few seconds the system hangs/freezes and I have to manually shut down the system with the power button and restart.
Results of garuda-inxi:
root=UUID=fb870b32-9d3f-40a8-9f3f-40654c06e4e2 rw rootflags=subvol=@
resume=UUID=b5416a9f-e921-41f1-9110-9b2bbce75c0e loglevel=3
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4901
date: 07/25/2022
Device-1: hidpp_battery_0 model: Logitech G700s serial: <filter> charge: 70%
(should be ignored) rechargeable: yes status: discharging
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3698 high: 4200 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
3: 3600 4: 3600 5: 3600 6: 3600 7: 3600 8: 4158 9: 4200 10: 3600 11: 3600
12: 3628 bogomips: 86406
protection
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: eVga.com.
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 07:00.0 chip-ID: 10de:2482 class-ID: 0300
Device-2: Logitech C920 HD Pro Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-2:2 chip-ID: 046d:0892
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 5360x1440 s-dpi: 95 s-size: 1433x389mm (56.42x15.31")
s-diag: 1485mm (58.46")
Monitor-1: DP-4 pos: primary,top-left res: 3440x1440 hz: 60 dpi: 109
size: 800x335mm (31.5x13.19") diag: 867mm (34.15") modes: N/A
Monitor-2: HDMI-0 pos: bottom-r res: 1920x1080 hz: 60 dpi: 96
size: 509x286mm (20.04x11.26") diag: 584mm (22.99") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 5-2:2 chip-ID: 046d:0892 pcie:
gen: 3 class-ID: 0102 serial: <filter> speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C920 HD Pro Webcam type: USB
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
Local Storage: total: 13.19 TiB used: 6.11 TiB (46.3%)
model: WDBRPG0010BNC-WRSN size: 931.51 GiB block-size: physical: 512 B
rev: 111130WD temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWE140
type: HDD rpm: 7200 serial: <filter> rev: FP1R scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MD04ACA500
size: 4.55 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: FP2A scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Toshiba model: External
USB 3.0 size: 3.64 TiB block-size: physical: 4096 B logical: 512 B
type: N/A serial: <filter> rev: 5438 scheme: GPT
ID-1: / raw-size: 896.83 GiB size: 896.83 GiB (100.00%) used: 54.3 GiB
(6.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 896.83 GiB size: 896.83 GiB (100.00%) used: 54.3
GiB (6.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 896.83 GiB size: 896.83 GiB (100.00%) used: 54.3
ID-5: /var/tmp raw-size: 896.83 GiB size: 896.83 GiB (100.00%) used: 54.3
ID-1: swap-1 type: zram size: 31.26 GiB used: 16 MiB (0.0%) priority: 100
System Temperatures: cpu: 38.0 C mobo: 28.0 C gpu: nvidia temp: 44 C
Fan Speeds (RPM): cpu: 837 case-1: 766 case-2: 0 case-3: 891 gpu: nvidia
fan: 0%
Power: 12v: 9.87 5v: N/A 3.3v: N/A vbat: 3.23
Processes: 335 Uptime: 3h 15m wakeups: 3 Memory: 31.26 GiB used: 5.64 GiB
(18.0%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1857 libs: 505
Garuda (2.6.9-1):
System install date: 2022-10-21
Last full system update: 2022-10-23
Failed units: irqbalance.service
Any ideas on what is going on? For now, I've set the monitor sleep to a large timeframe that I'll likely never have my computer on for....
I must say that I'm very impressed with this distro so far, thank you to the dev team for your efforts in making this distro "just work" and look great!
