Locale question
As someone who reads only one language, I don't often change my locale but I did when I was doing some testing. I seem to be having some challenges changing it back. Most everything is in English now except console applications.
Here is what my locale settings look like:
[garuda-snapper ~]>> localectl
System Locale: LANG=en_US.UTF-8
VC Keymap: us
X11 Layout: us
[garuda-snapper ~]>> echo $LANG
en_US.UTF-8
LANG=en_US.UTF-8
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_IDENTIFICATION="en_US.UTF-8"
LC_ALL=
Here is what happens when I run something in a terminal:
[garuda-snapper ~]>> sudo pacman -Sy
[sudo] Passwort fΓΌr dalto:
:: Paketdatenbanken werden synchronisiert …
core ist aktuell
extra ist aktuell
I am sure I have missed something, but I don't know what.
Post your inxi -Faz, please :slight_smile:
localectl
LC_NUMERIC=de_DE.UTF-8
LC_TIME=de_DE.UTF-8
LC_MONETARY=de_DE.UTF-8
LC_PAPER=de_DE.UTF-8
LC_NAME=de_DE.UTF-8
LC_ADDRESS=de_DE.UTF-8
LC_TELEPHONE=de_DE.UTF-8
LC_MEASUREMENT=de_DE.UTF-8
LC_IDENTIFICATION=de_DE.UTF-8
VC Keymap: de
X11 Layout: de
╭─[email protected] in ~ took 46ms
╰─> echo  $LANG
en_US.UTF-8
╰─> locale
LANG=en_US.UTF-8
LC_TIME=de_DE.UTF-8
LC_NAME=de_DE.UTF-8
LC_ALL=
╰─> sudo pacman -Sy
[sudo] password for sgs:
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
╭─[email protected] in ~ took 4s
Summary
Here are the formats settings:
sddm, plasma and all gui applications are in English.
OK, I just found this:
[garuda-snapper ~]>> env | grep LANGUAGE
LANGUAGE=en_US:de
The only reference I can see to that is in ~/.config/plasma-localerc
[Formats]
LANG=en_US.UTF-8
[Translations]
LANGUAGE=en_US:de
That corresponds to this setting:
I deleted german, which resolves the issue, but it doesn't seem like that should be needed.
Maybe settings from @dr460nf1r3 went to the ISO?
I can't remember the file name with the long list of all languages. Maybe there are en and de are unchecked, i mean without the # in front.
Hello.
I'm having a similiar issue. I've added Japanese as a secondary language.
Command line and some applications are using it over English.
localectl
VC Keymap: us
X11 Layout: us
locale
LANG=en_US.UTF-8
LC_NUMERIC=en_US.UTF-8
LC_TIME=en_US.UTF-8
LC_COLLATE=en_US.UTF-8
LC_MONETARY=en_US.UTF-8
LC_ALL=
echo $LANG
en_US.UTF-8
Have You Rebooted and can you provide your
inxi -Faz
Unfortunately, I never solved it, I just removed the secondary language.
The issue is that it seems to set the env variable LANGUAGE.
You could try setting LANGUAGE explicitly and see if that takes preference.
Yes, I have rebooted. Here is the output
inxi -Faz
Kernel: 5.15.8-227-tkg-pds x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: intel_pstate=passive BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-pds
root=UUID=0b597938-c2be-4d69-98aa-7454d3223d1f rw [email protected]
resume=UUID=7b0311f4-0e83-4091-aee7-5aa25086f458 loglevel=3
Type: Desktop System: ASUS product: N/A v: N/A serial:
Mobo: ASUSTeK model: TUF GAMING X570-PRO (WI-FI) v: Rev X.0x
serial: UEFI: American Megatrends v: 4021
date: 08/10/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3628 high: 3766 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3598 2: 3596
3: 3599 4: 3766 5: 3682 6: 3599 7: 3598 8: 3599 9: 3585 10: 3591 11: 3598
12: 3593 13: 3599 14: 3753 15: 3701 16: 3591 bogomips: 121725
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ASUSTeK
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 09:00.0
chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: [X.Org](http://X.Org) 1.21.1.2 compositor: kwin_x11 driver:
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 2560x1440 s-dpi: 106 s-size: 613x362mm (24.1x14.3")
s-diag: 712mm (28")
Monitor-1: HDMI-0 res: 2560x1440 hz: 60 dpi: 107
size: 610x356mm (24.0x14.0") diag: 706mm (27.8")
Device-1: NVIDIA GP106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 09:00.1 chip-ID: 10de:10f1
driver: snd_hda_intel v: kernel bus-ID: 0b:00.4 chip-ID: 1022:1487
Device-3: Logitech G430 Surround Sound Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2:3 chip-ID: 046d:0a4d
Sound Server-1: ALSA v: k5.15.8-227-tkg-pds running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac:
port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp5s0 state: down mac:
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
bus-ID: 1-4:2 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
Local Storage: total: 8.65 TiB used: 6.85 TiB (79.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
speed: 31.6 Gb/s lanes: 4 type: SSD serial: rev: S5Z42109
temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
type: HDD rpm: 5425 serial: rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: rev: 4B6Q
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST4000DM004-2CV104
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Generic model: Flash Disk
size: 7.5 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: rev: 8.07 scheme: GPT
ID-1: / raw-size: 896.76 GiB size: 896.76 GiB (100.00%)
used: 282.28 GiB (31.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 896.76 GiB size: 896.76 GiB (100.00%)
ID-4: /var/log raw-size: 896.76 GiB size: 896.76 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.76 GiB size: 896.76 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.46 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.32 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 39 C
Processes: 426 Uptime: 12m wakeups: 0 Memory: 31.32 GiB
used: 8.62 GiB (27.5%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1907 pacman: 1901 lib: 473 flatpak: 6 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
@dalto
Setting LANGUAGE explicitly to en_US.UTF8 does work.
