What to do, when proprietary drivers NVIDIA aren't working i.e. I click on booting with propriet. drivers(NVIDIA) and it is still booting nothing more?
Use free driver, install later if needed.
It works with free driver, but I want to try it with NVIDIA because I think it might have better graphic and resolution altogether
With garuda-settings - Hardware, I do the same. But last ISO's work for me with Nvidia driver, mh, just Nvidia
Thanks, but the problem is, I don't see anywhere option: "auto install proprietary driver" and any of the Nvidias
Maybe because I run it from the beggining screen with free drivers, but another option: booting with NVIDIA drivers doesn't function so I don't know
No, I do it this way often.
First try
Use terminal
garuda-settings-manager
Then Hardware...
If failed, search in forum to find other ways to install Nvidia.
Don't see anyway, but thank you
I will look for in forum
