Hello humans,
i have garuda and i dual-boot windows 10 with it , this problem only surfaced last week but i've been dual-booting for a long time, anyways when i open garuda everything looks normal for a minute then i get the limited connectivity notification and that's it, i tried disabling the firewall, restarting NetworkManager
, i used timeshift to go back before the latest update and still not working. what could this be? windows's internet is working normally so this is just linux
this is my garuda-inxi output:
root=UUID=b3d84ad5-60fd-45aa-a0f9-6fd3f466cafc rw rootflags=subvol=@
Type: Desktop System: Hewlett-Packard product: HP Z220 CMT Workstation
v: N/A serial: <superuser required> Chassis: type: 6
Mobo: Hewlett-Packard model: 1790 serial: <superuser required>
UEFI: Hewlett-Packard v: K51 v01.86 date: 06/13/2018
Info: model: Intel Core i7-3770 bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2755 high: 3894 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1748 2: 3889 3: 2398
4: 2831 5: 3631 6: 2002 7: 3894 8: 1650 bogomips: 54277
Type: l1tf
Device-1: Intel IvyBridge GT2 [HD Graphics 4000] vendor: Hewlett-Packard
driver: i915 v: kernel ports: active: HDMI-A-1
empty: DP-1, DP-2, HDMI-A-2, VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0162
loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
Monitor-1: HDMI-A-1 mapped: HDMI1 model: Philips 271P4 serial: <filter>
built: 2015 res: 1920x1080 hz: 60 dpi: 81 gamma: 1.2
size: 600x340mm (23.62x13.39") diag: 685mm (27") ratio: 16:9 modes:
OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 22.0.1 compat-v: 3.1 direct render: Yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: f080 bus-ID: 00:19.0 chip-ID: 8086:1502
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0
port: f060 bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 577.55 GiB used: 104.91 GiB (18.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hikvision model: HS-SSD-C100 120G
type: SSD serial: <filter> rev: 979 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500DM002-1BD142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: KC65
ID-1: / raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
used: 104.89 GiB (94.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 25.5 MiB (9.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
ID-4: /var/log raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
ID-5: /var/tmp raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.07 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 284 Uptime: 29m wakeups: 0 Memory: 15.07 GiB
used: 3.59 GiB (23.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1752 apt: 0 pacman: 1746 lib: 486
flatpak: 6 Shell: fish v: 3.4.1 running-in: yakuake inxi: 3.3.14
Garuda (2.5.8-1):
System install date: 2021-10-18
Last full system update: 2022-04-05
Snapshots: Timeshift (maybe)
