Libreoffice doesn't recognize pasting ñ and accent mark
Hi
Since last weekend kernel update, when I paste spanish text in Libreoffice fresh, it doesn’t recognize ñ and accent marks, this doesn’t happen with kwrite
Thank you
─λ garuda-inxi
Kernel: 6.13.1-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=86dcc3e3-80bf-49c1-99cc-7832f99acbbb rw rootflags=subvol=@
quiet rd.luks.uuid=aef6912e-f7bf-46f9-83e0-a26147f00141
resume=/dev/mapper/luks-aef6912e-f7bf-46f9-83e0-a26147f00141 loglevel=3
Type: Laptop System: Dell product: Inspiron 15 3535 v: 1.17.0
serial: <superuser required> Chassis: type: 10 v: 1.17.0
Mobo: Dell model: 04RG2X v: A00 serial: <superuser required> part-nu: 0C3E
uuid: <superuser required> UEFI: Dell v: 1.17.0 date: 09/13/2024
ID-1: BAT1 charge: 40.8 Wh (100.0%) condition: 40.8/40.8 Wh (100.0%)
volts: 12.9 min: 11.2 model: BYD DELL PG8YJ458 type: Unknown
serial: <filter> status: full
Info: model: AMD Ryzen 5 7520U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0xA0 (160) stepping: 0
microcode: 0x8A0000A
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 4241 min/max: 400/4384 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4241 2: 4241 3: 4241
4: 4241 5: 4241 6: 4241 7: 4241 8: 4241 bogomips: 44712
Device-1: Advanced Micro Devices [AMD/ATI] Mendocino vendor: Dell
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, Writeback-1 bus-ID: 03:00.0
chip-ID: 1002:1506 class-ID: 0300 temp: 57.0 C
Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2
chip-ID: 1bcf:28d3 class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 model: LG Display 0x0738 built: 2022 res: mode: 1920x1080
hz: 120 scale: 125% (1.25) to: 1536x864 dpi: 142 gamma: 1.2
max: 1920x1080 min: 640x480
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 610M (radeonsi
raphael_mendocino LLVM 19.1.7 DRM 3.59 6.13.1-zen3-1-zen)
device-ID: 1002:1506 memory: 500 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 10 device: 0 type: integrated-gpu name: AMD
Radeon 610M (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:1506
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
Audio vendor: Dell driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:1640 class-ID: 0403
vendor: Dell driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Dell driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.13.1-zen3-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 0bda:c829
rfk-block: hardware: no software: no address: <filter> bt-v: 4.2 lmp-v: 8
Local Storage: total: 476.94 GiB used: 239.07 GiB (50.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Phison model: P0221 NVMe 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 21020104 temp: 41.9 C
ID-1: / raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
used: 42.93 GiB (87.9%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 664 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p8 maj-min: 259:8
ID-3: /home raw-size: 370.12 GiB size: 370.12 GiB (100.00%)
used: 195.63 GiB (52.9%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-f576e65a-1bd5-48ea-8211-f844f38fb542
ID-4: /var/log raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-5: /var/tmp raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-1: swap-1 type: partition size: 20.21 GiB used: 518.2 MiB (2.5%)
mapped: luks-aef6912e-f7bf-46f9-83e0-a26147f00141
ID-2: swap-2 type: zram size: 6.97 GiB used: 6.97 GiB (100.0%)
max-streams: 8 dev: /dev/zram0
System Temperatures: cpu: 68.0 C mobo: 51.0 C sodimm: SODIMM C gpu: amdgpu
temp: 57.0 C
Fan Speeds (rpm): cpu: 3400
Memory: total: 8 GiB note: est. available: 6.97 GiB used: 5.81 GiB (83.4%)
Processes: 397 Power: uptime: 10h 25m states: freeze,mem,disk
suspend, test_resume image: 2.77 GiB services: org_kde_powerdevil,
Packages: 2352 pm: pacman pkgs: 2344 libs: 609 tools: octopi,paru
pm: flatpak pkgs: 8 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date:     2025-01-22
Last full system update: 2025-02-08 ↻
I don’t think this has anything to deal with Garuda (and with the kernel).
Works fine here, with same kernel and libreoffice still instead of fresh.
I haven’t found it in the libreoffice bug tracker either. But did a very quick search:
https://bugs.documentfoundation.org/
Maybe this is related to the other issue you opened on the keyboard layout and/or relevant tests?
PS1: I don’t have Spanish and/or Latin-American Spanish set-up in my system. I copied from browser (deepl) and pasted into LibreOffice.
PS2: If you search for “paste” (or similar) in the bug tracker you’ll find a lot of very recent bug reports, so I believe the problem stems from the LibreOffice Fresh latest update (07-Feb-2025)…
