Libinput gestures not working for walk through desktop
Hi, I I'm very new to Linux and Garuda is my first distro.
I was trying to assign walk through desktop to the swipe right with four fingers gesture using libinput and it was working too, but now it have suddenly stopped working. I tried to assign it to three finger swipe gestures but that is also not working. All other gestures like show desktop grid are working, just walk through desktop is not working.
It probably happened after i tried to remap function keys using xmodmap, but i am not sure.
Also i want to configure a lot of things like transparency of dock, corner roundness etc. is there a good guide for that somewhere, i could not find a lot of things on google.
Thanks for helping.
Kernel: 6.4.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=f5e179f1-6d49-4900-8ea5-59f5ec6c0e95 rw rootflags=subvol=@
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506QM_FA506QM
Mobo: ASUSTeK model: FA506QM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: FA506QM.314 date: 01/07/2023
ID-1: BAT1 charge: 77.5 Wh (100.0%) condition: 77.5/90.2 Wh (85.9%)
volts: 17.1 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1459 high: 3200 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1200 2: 1200
3: 1200 4: 1200 5: 1198 6: 1200 7: 1200 8: 1355 9: 3200 10: 1200 11: 1200
12: 1200 13: 3200 14: 1200 15: 1200 16: 1200 bogomips: 102204
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 535.98 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 55.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 322e:202c
class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x004d built: 2019
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.4.10-zen2-1-zen) direct-render: Yes
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.4.10-zen2-1-zen status: kernel-api tools: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 8087:0029
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 476.94 GiB used: 349.08 GiB (73.2%)
fw-rev: FXM7201Q temp: 36.9 C scheme: GPT
ID-1: / raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
used: 13.77 GiB (28.2%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
used: 34.2 MiB (13.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-4: /var/log raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-5: /var/tmp raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.03 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 61.8 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (rpm): cpu: 0
Processes: 408 Uptime: 27m wakeups: 1551 Memory: total: 16 GiB note: est.
available: 15.03 GiB used: 4.56 GiB (30.3%) Init: systemd v: 254
pm: pacman pkgs: 1361 libs: 343 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date:     2023-08-15
Last full system update: 2023-08-17
Relevant software:       snapper(custom) NetworkManager dracut nvidia-dkms
