I haven’t had any trouble with Garuda in quite a long while – which is great news. There is however just 1 annoying issue.
I bought a new Lenovo laptop. The power button turns blue on economy mode, white on balance, red on performance and purple on custom.
Setting power profile to Performance from Garuda sets it purple (custom).
Setting it via keyboard shortcut puts the light red.
I benchmarked it: hardware-set performance (Red) is considerably faster than Linux-set performance (purple).
No big deal… I just set it to Red via keyboard shortcut. But it resets to Custom after every reboot.
Why is Linux performance profile not matching Lenovo’s performance profile set via keyboard?
Is there a way to solve this issue?
Kernel: 6.18.3-1-cachyos arch: x86_64 bits: 64 compiler: clang v: 21.1.6
root=UUID=51ef4a7a-fb89-43c3-a466-7318e0363e7e rw rootflags=subvol=@
quiet i915.dmc_firmware_path= loglevel=3
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
Type: Laptop System: LENOVO product: 83JE v: LOQ 15IRX10
serial: <superuser required> Chassis: type: 10 v: LOQ 15IRX10
Mobo: LENOVO model: LNVNB161216 v: SDK0T76464 WIN
serial: <superuser required> part-nu: LENOVO_MT_83JE_BU_idea_FM_LOQ 15IRX10
uuid: <superuser required> Firmware: UEFI vendor: LENOVO v: R3CN37WW
date: 06/10/2025
ID-1: BAT1 charge: 60.8 Wh (99.5%) condition: 61/60 Wh (101.7%) volts: 13.3
min: 12.92 model: ATL L24N4PK3 type: Li-poly serial: <filter> charging:
status: full type: standard avail: long_life,standard cycles: 2
Info: model: 13th Gen Intel Core i5-13450HX bits: 64 type: MST AMCP
process: Intel 7 (10nm) family: 6 model-id: 0xBF (191) stepping: 2
microcode: 0x3D
Topology: cpus: 1x dies: 1 clusters: 7 cores: 10 threads: 16 mt: 6 tpc: 2
st: 4 smt: enabled cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32
KiB, 4x64 KiB L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB
desc: 1x20 MiB
Speed (MHz): avg: 2798 min/max: 800/4600:3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 2798 2: 2798 3: 2798
4: 2798 5: 2798 6: 2798 7: 2798 8: 2798 9: 2798 10: 2798 11: 2798 12: 2798
13: 2798 14: 2798 15: 2798 16: 2798 bogomips: 83558
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel Alder Lake-S [UHD Graphics] vendor: Lenovo driver: i915
v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: none off: eDP-2 empty: DP-1, DP-2, DP-3, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:468b class-ID: 0300
Device-2: NVIDIA GB207M [GeForce RTX 5050 Max-Q / Mobile] vendor: Lenovo
driver: nvidia v: 590.48.01 alternate: nouveau,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-11) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 5 speed: 32 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: eDP-1 bus-ID: 01:00.0 chip-ID: 10de:2dd8
Device-3: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 174f:11b5
gpu: i915,nv_platform,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-1 model: Samsung serial: <filter> built: 2016 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 48 gamma: 1.2
size: 1210x680mm (47.64x26.77") diag: 1168mm (46") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: eDP-2 model-id: CSW 0x150f serial: <filter> built: 2023
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.3.3-arch1.1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ADL-S
GT0.5) device-ID: 8086:468b memory: 22.63 GiB unified: yes
display-ID: :1.0
API: Vulkan v: 1.4.335 layers: 13 device: 0 type: integrated-gpu
name: Intel UHD Graphics (ADL-S GT0.5) driver: mesa intel
v: 25.3.3-arch1.1.1 device-ID: 8086:468b surfaces: N/A device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 5050 Laptop GPU driver: nvidia
v: 590.48.01 device-ID: 10de:2dd8 surfaces: N/A device: 2 type: cpu
name: llvmpipe (LLVM 21.1.6 256 bits) driver: mesa llvmpipe
v: 25.3.3-arch1.1.1 (LLVM 21.1.6) device-ID: 10005:0000 surfaces: N/A
Device-1: Intel Raptor Lake High Definition Audio vendor: Lenovo
bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0401
Device-2: NVIDIA GB207 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:22ec class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 1-3.2:4 chip-ID: 08bb:29b0 class-ID: 0300
API: ALSA v: k6.18.3-1-cachyos status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
port: 4000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: Lenovo
driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 09:00.0 chip-ID: 10ec:b852 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 0bda:4853
Local Storage: total: 5.92 TiB used: 1.06 TiB (17.8%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Micron
model: MTFDKCD512QGN-1BN1AABLA size: 476.94 GiB block-size: physical: 512 B
fw-rev: 1001V8LN temp: 50.9 C scheme: GPT
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234200WD temp: 41.9 C scheme: GPT
model: WD40NDZW-11A8JS1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1023 scheme: GPT
ID-1: / raw-size: 1.81 TiB size: 1.81 TiB (100.00%) used: 804.44 GiB (43.5%)
fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:5
ID-2: /boot/efi raw-size: 625 MiB size: 623.7 MiB (99.80%)
used: 10.7 MiB (1.7%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-3: /home raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
used: 804.44 GiB (43.5%) fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:5
ID-4: /var/log raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-1: swap-1 type: zram size: 23.18 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p2 maj-min: 259:4
System Temperatures: cpu: 52.5 C mobo: N/A
Memory: total: 24 GiB note: est. available: 23.18 GiB used: 6.74 GiB (29.1%)
Processes: 403 Power: uptime: 9h 46m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 9.22 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1699 libs: 394 tools: octopi,paru Compilers:
clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.9 default: fish v: 4.3.2
running-in: konsole inxi: 3.3.40
Garuda (2.11.1-1):
System install date: 2024-07-17
Garuda release: 240428
Last full system update: 2026-01-08
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
25/26 checks run in 0.84 seconds ⌛
Powered by garuda-health 🦅
