Ledge-PC garuda-inxi
Kernel: 5.16.15-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=0932f3fb-ebe7-4906-a6eb-2969d12d2e64 rw [email protected]
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-F GAMING v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 4002 date: 06/15/2021
Info: model: AMD Ryzen 5 3600X socket: AM4 bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x71 (113) stepping: 0
microcode: 0x8701021
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3800 min/max: 2200/4409 boost: enabled
base/boost: 3800/4400 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3800 2: 3800 3: 3800 4: 3800
5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800
bogomips: 91032
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: eVga.com.
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 08:00.0
chip-ID: 10de:1c03 class-ID: 0300
Device-2: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 09:00.0 chip-ID: 10de:2216 class-ID: 0300
Display: server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
gpu: nvidia,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 91 s-size: 1250x402mm (49.2x15.8")
s-diag: 1313mm (51.7")
Monitor-1: DP-2 pos: bottom-l res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
Monitor-2: HDMI-0 pos: primary,top-right res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: eVga.com.
link-max: lanes: 16 bus-ID: 08:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1
chip-ID: 10de:1aef class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.16.15-zen1-1-zen running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
Local Storage: total: 3.41 TiB used: 38.36 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: FireCuda 520 SSD ZP1000GM30002 size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD
serial: <filter> rev: STNSC014 temp: 35.9 C scheme: GPT
SMART: yes health: PASSED on: 129d 20h cycles: 612
read-units: 31,659,010 [16.2 TB] written-units: 27,945,055 [14.3 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
family: based SSDs size: 232.89 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 3B6Q temp: 25 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 35d 15h cycles: 202
written: 1.81 TiB
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
family: based SSDs size: 465.76 GiB block-size: physical: 512 B
rev: 4B6Q temp: 23 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 222d 20h cycles: 898
written: 8.6 TiB
ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: HDWD120
family: P300 (CMR) size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: ACF0 temp: 30 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 1y 188d 7h cycles: 2485
ID-1: / raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
used: 38.33 GiB (16.5%) fs: btrfs block-size: 4096 B dev: /dev/sda1
maj-min: 8:1
used: 29.8 MiB (31.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
maj-min: 8:1
ID-4: /var/log raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
maj-min: 8:1
ID-5: /var/tmp raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
maj-min: 8:1
ID-1: swap-1 type: zram size: 15.59 GiB used: 512 KiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 1307%
Processes: 342 Uptime: 5m wakeups: 0 Memory: 15.59 GiB
used: 2.7 GiB (17.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1708 lib: 475 Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.6-2):
System install date:     2022-03-12
Last full system update: 2022-03-20
Windows dual boot:       Yes
Failed units:            bluetooth-autoconnect.service
