Latte very laggy on my dual monitor(primary)
Firstly, love the KDE Dragonized look and feel, it is amazing. Love the speed love everything. Thank you for making this. I feel like the search is finally over.
I freshly installed Garuda KDE Dragonized on my new MSI Bravo 17. It has AMD Ryzen 7 CPU and AMD Raedon RX GPU. Everything works amazing except when I connect my monitor and use it as primary display. My monitor is 60 Hz and laptop is 144 Hz. When I move my mouse pointer over the latte dock its super laggy. It is unusable I cannot click on anything because the animation never ends. Even the app launcher has the same behavior. When I make my laptop primary everything works well. I am using it this way now.
Output of inxi:
System:    Kernel: 5.11.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
           root=UUID=a8d92337-3c71-41c2-8fe4-2aee41df6bbd rw [email protected] quiet
           cryptdevice=UUID=e1f74f05-2a0b-4eef-ba80-cc1a9325081e:luks-e1f74f05-2a0b-4eef-ba80-cc1a9325081e
           root=/dev/mapper/luks-e1f74f05-2a0b-4eef-ba80-cc1a9325081e splash
           Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 2 dm: SDDM
Machine:   Type: Laptop System: Micro-Star product: Bravo 17 A4DDR v: REV:1.0 serial: <filter>
           Chassis: type: 10 serial: <filter>
           Mobo: Micro-Star model: MS-17FK v: REV:1.0 serial: <filter> UEFI: American Megatrends
           v: E17FKAMS.117 date: 10/29/2020
Battery:   ID-1: BAT1 charge: 50.5 Wh (96.7%) condition: 52.2/51.3 Wh (101.7%) volts: 12.8
           min: 11.4 model: MSI Corp. MS-17FK type: Li-ion serial: N/A status: Unknown
CPU:       Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
           arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600104 cache:
           L2: 4 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92619
           Speed: 1752 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz): 1: 1752
           2: 1907 3: 1584 4: 2292 5: 2983 6: 2420 7: 3175 8: 4275 9: 3300 10: 1605 11: 2699
           12: 3688 13: 1892 14: 1891 15: 2123 16: 2777
           Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP:
           conditional, RSB filling
Graphics:  Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M] vendor: Micro-Star MSI
           driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:7340 class-ID: 0380
           Device-2: AMD Renoir vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 07:00.0
           Device-3: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 1-4:3 chip-ID: 5986:211c
           class-ID: 0e02
           Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu,ati
           unloaded: modesetting,radeon alternate: fbdev,vesa display-ID: :0 screens: 1
           Screen-1: 0 s-res: 1921x2160 s-dpi: 96 s-size: 506x570mm (19.9x22.4")
           s-diag: 762mm (30")
           Monitor-1: eDP res: 1920x1080 hz: 144 dpi: 128 size: 382x215mm (15.0x8.5")
           diag: 438mm (17.3")
           Monitor-2: HDMI-A-1-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
           diag: 686mm (27")
           OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.11.16-zen1-1-zen LLVM 11.1.0)
           v: 4.6 Mesa 21.0.3 direct render: Yes
Audio:     Device-1: AMD Navi 10 HDMI Audio vendor: Micro-Star MSI driver: snd_hda_intel
           v: kernel bus-ID: 03:00.1 chip-ID: 1002:ab38 class-ID: 0403
           Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Micro-Star MSI
           driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 07:00.5
           Device-3: AMD Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
           v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
           Sound Server-1: ALSA v: k5.11.16-zen1-1-zen running: yes
           Sound Server-4: PipeWire v: 0.3.26 running: no
Network:   Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
           chip-ID: 8086:2723 class-ID: 0280
           vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 05:00.0
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:2
           chip-ID: 8087:0029 class-ID: e001
Drives:    Local Storage: total: 476.94 GiB used: 16.41 GiB (3.4%)
           ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AI1
           size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
           rotation: SSD serial: <filter> rev: ECFK52.8 temp: 41.9 C scheme: GPT
Partition: ID-1: / raw-size: 256 GiB size: 256 GiB (100.00%) used: 16.38 GiB (6.4%) fs: btrfs
           dev: /dev/dm-0 maj-min: 254:0 mapped: luks-e1f74f05-2a0b-4eef-ba80-cc1a9325081e
           ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%) used: 26 MiB (8.8%) fs: vfat
           ID-3: /home raw-size: 256 GiB size: 256 GiB (100.00%) used: 16.38 GiB (6.4%)
           ID-4: /var/log raw-size: 256 GiB size: 256 GiB (100.00%) used: 16.38 GiB (6.4%)
           ID-5: /var/tmp raw-size: 256 GiB size: 256 GiB (100.00%) used: 16.38 GiB (6.4%)
Swap:      Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
           ID-1: swap-1 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767
           ID-2: swap-2 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767
           dev: /dev/zram1
           ID-3: swap-3 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767
           dev: /dev/zram2
           ID-4: swap-4 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767
           dev: /dev/zram3
           ID-5: swap-5 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767
           dev: /dev/zram4
           ID-6: swap-6 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767
           dev: /dev/zram5
Sensors:   System Temperatures: cpu: 60.0 C mobo: 58.0 C
           GPU: device: amdgpu temp: 47.0 C device: amdgpu temp: 50.0 C mem: 0.0 C fan: 65535
           watts: 4.00
Info:      Processes: 440 Uptime: 2h 31m wakeups: 1 Memory: 30.83 GiB used: 8.65 GiB (28.1%)
           Init: systemd v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages:
           pacman: 1381 lib: 351 Shell: fish v: 3.2.1 running-in: alacritty inxi: 3.3.04
And keep doing that.
Primary is a technical term, not positional or other personal preference.
Laptop's monitor is Primary by design/definition.
Why do you think you have to change the Primary monitor setting?
I guess I have always used it that way. I was able to add another dock to latte and it worked. But yes I understand. Thank you.
