Kernel: 5.16.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=9352e1a4-8d9b-416d-9ca2-0c7036732513 rw [email protected]
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ASUS TUF Dash F15 FX516PM_FX516PM
Mobo: ASUSTeK model: FX516PM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: FX516PM.322 date: 08/27/2021
ID-1: BAT0 charge: 32.5 Wh (44.0%) condition: 73.8/76.0 Wh (97.1%)
status: Charging cycles: 33
Info: model: 11th Gen Intel Core i7-11370H bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x88
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2617 high: 3426 min/max: 400/4800 scaling:
driver: intel_pstate governor: performance cores: 1: 2533 2: 3072 3: 3062
4: 2560 5: 1272 6: 3426 7: 3277 8: 1736 bogomips: 52838
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
loaded: intel,modesetting,nouveau alternate: fbdev,nv,vesa display-ID: :0
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 144 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.16.7-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 2e:00.0
IF-ID-1: enp0s20f0u4 state: unknown speed: -1 duplex: half mac: <filter>
bus-ID: 3-10:3 chip-ID: 8087:0026 class-ID: e001
address: <filter>
Device-2: Samsung GT-I9070 (network tethering USB debugging enabled)
type: USB driver: rndis_host v: kernel bus-ID: 3-4:2 chip-ID: 04e8:6864
Local Storage: total: 715.41 GiB used: 57.08 GiB (8.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: M Series NVMe SSD 256G
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: V2.18.0
temp: 45.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
rev: FXM7201Q temp: 38.9 C scheme: GPT
ID-1: / raw-size: 91 GiB size: 91 GiB (100.00%) used: 57.08 GiB (62.7%)
used: 563 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 91 GiB size: 91 GiB (100.00%)
used: 57.08 GiB (62.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 91 GiB size: 91 GiB (100.00%)
ID-5: /var/tmp raw-size: 91 GiB size: 91 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.32 GiB used: 4.5 MiB (0.0%)
System Temperatures: cpu: 59.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2600
Processes: 350 Uptime: 9m wakeups: 1097 Memory: 15.32 GiB
used: 3.97 GiB (25.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: note: see --pkg pacman: 2156 lib: 397
Shell: fish v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2021-10-15
Last full system update: 2022-02-08
When logging into Garuda, baloo_file produced a segmentation fault. My toolbar + tray (Latte) were not present despite htop reporting it was running, and my networks were messed up (no internet and stuck at Waiting for authorisation) despite NetworkManager in systemctl looking normal.
I tried restoring an earlier snapshot that was perfectly fine, nothing resolved. I tried a system update, no luck. I also tried resetting Latte and other configs, I tried reinstalling baloo and reinstalling all system packages. Nothing.
Complete fresh install is a last resort. There is a lot on this OS that would take many hours to get back.
