Latte Dock not working
Hello.
  Kernel: 5.16.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=29aa3365-2bc5-4be4-9e27-13fa307c81ec rw rootflags=subvol=@
  Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 info: latte-dock
  Type: Desktop Mobo: Gigabyte model: H310M H 2.0 v: x.x
    serial: <superuser required> UEFI: American Megatrends v: F12
    date: 08/13/2019
  Info: model: Intel Core i3-9100F bits: 64 type: MCP arch: Coffee Lake
    family: 6 model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xEC
    desc: 1x6 MiB
  Speed (MHz): avg: 3956 high: 4126 min/max: 800/4200 scaling:
    driver: intel_pstate governor: performance cores: 1: 4126 2: 3482 3: 4099
    4: 4119 bogomips: 28800
  Type: l1tf
    STIBP: disabled, RSB filling
    vendor: Micro-Star MSI driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 ports: active: DP-2,HDMI-A-1 empty: DP-1,DVI-D-1,HDMI-A-2
    bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
  Screen-1: 0 s-res: 3280x1080 s-dpi: 96 s-size: 865x285mm (34.06x11.22")
    s-diag: 911mm (35.86")
  Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,left model: ASUS VP228
    serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
    size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9 modes:
  Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model-id: HIC 0x0001
    serial: <filter> built: 2011 res: 1360x768 hz: 60 dpi: 135 gamma: 0.97
    size: 256x192mm (10.08x7.56") diag: 378mm (14.9") ratio: 4:3, 5:4 modes:
    max: 1024x768 min: 640x480
  OpenGL: renderer: AMD Radeon RX 590 Series (POLARIS10 DRM 3.44.0
    5.16.16-zen1-1-zen LLVM 13.0.1)
  Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
    lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.35 TiB used: 96.96 GiB (7.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD110
    speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A8R0
    scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 240GB
    type: SSD serial: <filter> rev: 04RL scheme: GPT
    model: WDS240G2G0A-00JH30 size: 223.57 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0400
  ID-1: / raw-size: 79.1 GiB size: 79.1 GiB (100.00%) used: 32.75 GiB (41.4%)
    fs: btrfs dev: /dev/sdc4 maj-min: 8:36
  ID-2: /boot/efi raw-size: 511.6 MiB size: 510.6 MiB (99.80%)
    used: 580 KiB (0.1%) fs: vfat dev: /dev/sdc6 maj-min: 8:38
  ID-3: /home raw-size: 79.1 GiB size: 79.1 GiB (100.00%)
    used: 32.75 GiB (41.4%) fs: btrfs dev: /dev/sdc4 maj-min: 8:36
  ID-4: /var/log raw-size: 79.1 GiB size: 79.1 GiB (100.00%)
  ID-5: /var/tmp raw-size: 79.1 GiB size: 79.1 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.57 GiB used: 1024 KiB (0.0%)
  System Temperatures: cpu: 27.8 C mobo: 16.8 C gpu: amdgpu temp: 47.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1091
  Processes: 294 Uptime: 5m wakeups: 0 Memory: 15.57 GiB
  used: 2.44 GiB (15.7%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 Packages: note: see --pkg apt: 0 pacman: 1699 lib: 488 pkg: 0
  flatpak: 0 Shell: fish v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.14
Garuda (2.5.6-2):
  System install date:     2022-03-27
  Last full system update: 2022-03-30
  Failed units:            bluetooth-autoconnect.service
hello, when I turned on my computer today, I saw that the terminal has been updated. I think the update has come. After restarting my computer, the latte dock was not working. When I tried to open it from the terminal, I was getting the already open error. Could the error have something to do with the update?
Hi there, welcome.
What do you mean with this?
For this:
Have you tried resetting latte config to default values with the Garuda Assistant?
When I opened the terminal bash was running instead of fish and the tabs menu came up. I thought my settings might have been reset or the update might have arrived.
I am now trying the solution you suggested.
yeah its worked!
Thank you so much i love Garuda.
An update never touches the user configurations stored in the home folder.
As you'll see, you will be able to reset many other configurations from Garuda Assistant if necessary.
I mark it solved the #412* area question.
*Before you open a new help request, read relevant sections of the Arch and Garuda wiki.
