Can you'll enable option by default for the
windowTitle
widget for the Top latte panel...
And this this for
windowAppMenu
widget for Top Latte Panel, it would help those who are using Multi-Monitor Setups...
And also these options for Bottom Latte Dock...It would help isolate the applications displayed in the dock for each Screen/VirtualDesktop/Activity...
I believe these modifications will enhance the user experience on Multi - Monitor Setups...
Thank you
