I have a strange issue that I'm not quite sure how to describe, but here goes:
With Latte Dock running (centered on the bottom of the screen), the bottom 1/3 of my screen is unusable. By that I mean that I can resize windows by dragging the bottom of the window, I can't click on anything in any app within the bottom 1/3 of the screen.
Any ideas on how to troubleshoot this issue?
filo
February 23, 2022, 2:28pm
2
Please provide your garuda-inxi
as per new topic template.
At first glance I would think of a problem with the compositor.
Kernel: 5.16.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/timeshift-btrfs/snapshots/2022-02-22_11-33-35/@/boot/vmlinuz-linux-zen
root=UUID=ecab03e1-a558-41c4-9a5d-c968be69fb64 rw
rootflags=subvol=timeshift-btrfs/snapshots/2022-02-22_11-33-35/@ quiet
cryptdevice=UUID=aafdf48b-7261-469c-8910-7f87d7aec02d:luks-aafdf48b-7261-469c-8910-7f87d7aec02d
root=/dev/mapper/luks-aafdf48b-7261-469c-8910-7f87d7aec02d splash
resume=/dev/mapper/luks-79407f78-876d-4460-8848-f2923cf77026 loglevel=3
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Desktop System: Micro product: G510 v: 1.0
Mobo: ASUSTeK model: PRIME B550M-A AC v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2006
date: 03/19/2021
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3709 high: 4637 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3643 2: 3595
3: 3590 4: 3589 5: 3693 6: 3578 7: 3592 8: 3615 9: 3804 10: 4637 11: 3587
12: 3589 bogomips: 88632
IBRS_FW, STIBP: always-on, RSB filling
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT / 6800M] vendor: Tul
driver: amdgpu v: kernel bus-ID: 0d:00.0 chip-ID: 1002:73df class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: DisplayPort-2 res: 2560x1440 hz: 165 dpi: 93
size: 697x392mm (27.4x15.4") diag: 800mm (31.5")
OpenGL: renderer: AMD Radeon RX 6700 XT (NAVY_FLOUNDER DRM 3.44.0
5.16.10-zen1-1-zen LLVM 13.0.1)
v: 4.6 Mesa 21.3.6 direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 0d:00.1 chip-ID: 1002:ab28
driver: snd_hda_intel v: kernel bus-ID: 0f:00.4 chip-ID: 1022:1487
Sound Server-1: ALSA v: k5.16.10-zen1-1-zen running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.47 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: ASUSTeK driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: e000
bus-ID: 09:00.0 chip-ID: 10ec:c821 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: d000
bus-ID: 0a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp10s0 state: down mac: <filter>
Device-1: ASUSTek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-5:5 chip-ID: 0b05:18ea class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 931.51 GiB used: 429.19 GiB (46.1%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
rev: 211210WD temp: 33.9 C scheme: GPT
ID-1: / raw-size: 896.86 GiB size: 896.86 GiB (100.00%)
used: 429.18 GiB (47.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-aafdf48b-7261-469c-8910-7f87d7aec02d
used: 706 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 896.86 GiB size: 896.86 GiB (100.00%)
ID-4: /var/log raw-size: 896.86 GiB size: 896.86 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.86 GiB size: 896.86 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.32 GiB used: 2.8 MiB (0.0%)
mapped: luks-79407f78-876d-4460-8848-f2923cf77026
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 52.0 C
mem: 40.0 C
Processes: 381 Uptime: 36m wakeups: 0 Memory: 31.32 GiB
used: 6.06 GiB (19.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1989 pacman: 1979 lib: 565 flatpak: 10
Shell: fish v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.12
Garuda (2.5.5-1):
System install date: 2021-11-04
Last full system update: 2022-02-23
Snapshots: Timeshift
Failed units: anbox-container-manager.service systemd-networkd-wait-online.service
filo
February 23, 2022, 2:41pm
4
I edited your garuda-inxi for proper formatting. Give a look , also here:
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It's especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy yo…
filo
February 23, 2022, 2:43pm
5
Careful, you’re booted off a snapshot, so you should open the btrfs assistant (or timeshift application, I’m currently with snapper), locate that snapshot and restore it, then reboot.
Good catch. I'll do that right now.
Let's try this again.
root=UUID=ecab03e1-a558-41c4-9a5d-c968be69fb64 rw rootflags=subvol=@
quiet
Desktop: KDE Plasma 5.24.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
date: 03/19/2021
Speed (MHz): avg: 3888 high: 4543 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4026 2: 3683
3: 3844 4: 3666 5: 3645 6: 4543 7: 3711 8: 3708 9: 4098 10: 4063 11: 3711
12: 3965 bogomips: 88628
address: <filter>
Local Storage: total: 931.51 GiB used: 429.21 GiB (46.1%)
rev: 211210WD temp: 34.9 C scheme: GPT
used: 429.21 GiB (47.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 58.0 C
mem: 46.0 C
Processes: 398 Uptime: 1m wakeups: 0 Memory: 31.32 GiB
used: 5.36 GiB (17.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 2008 pacman: 1998 lib: 567 flatpak: 10
inxi: 3.3.12
Garuda (2.5.5-1):
Last full system update: 2022-02-22
Snapshots: Timeshift (maybe)
Resolved.
Restoring the snapshot fixed the issue.
system
Closed
February 25, 2022, 2:55pm
10
