When I boot my PC my latte dock is hidden, and also my top menu bar, it seems like almost all process where not initialized for some reason. This is the third time that this bug happens to me in 2 weeks
I tried the solution on this post Can't start Latte dock anymore
cp -rf /etc/skel/. ~/
But now I cant change the configuration of Konsole or any other program, the konsole keeps using fish even when I changed the configuration to use zsh. I want to go back to my personal config before this bug happened, but I cant.
inxi -Faz
Kernel: 5.15.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=2388a6d1-7c1f-4a3a-a706-424269cd9d94 rw rootflags=subvol=@
Type: Desktop Mobo: ASRock model: A320M-HD serial: <superuser required>
UEFI: American Megatrends v: P5.40 date: 07/09/2019
Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen/Zen+ note: check family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108102
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2936 high: 2949 min/max: 1400/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2912 2: 2942
3: 2949 4: 2943 bogomips: 28802
STIBP: disabled, RSB filling
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M] vendor: ASRock
driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:7340 class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
s-diag: 582mm (22.9")
Monitor-1: DisplayPort-2 res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 03:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 09:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.11-zen1-1-zen running: yes
vendor: ASRock driver: r8169 v: kernel port: e000 bus-ID: 08:00.0
Local Storage: total: 1.14 TiB used: 18.21 GiB (1.6%)
model: WD10EZEX-75WN4A1 size: 931.51 GiB block-size: physical: 4096 B
rev: 7113 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Lexar model: 256GB SSD
type: SSD serial: <filter> rev: 505 scheme: GPT
ID-1: / raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
used: 18.21 GiB (7.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 562 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
ID-4: /var/log raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
ID-5: /var/tmp raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.61 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 38.0 C mem: 0.0 C
Processes: 262 Uptime: 8m wakeups: 0 Memory: 15.61 GiB
used: 2.77 GiB (17.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1191 lib: 301 Shell: Zsh v: 5.8
running-in: konsole inxi: 3.3.11
