Latest update broke latte-dock and Fonts
Hello,
the latest update broke my Latte Dock and Fonts. The Fonts are bigger are too big in the latte dock Panel and at the application top bar.
Also Latte dock does not start by default and when i call latte-dock --replace this errors apprear
Icon theme "gnome" not found.
file:///usr/lib/qt/qml/org/kde/kirigami.2/private/RefreshableScrollView.qml:175:13: QML Binding: Not restoringprevious value because restoreMode has not been set.
This behavior is deprecated.
You have to import QtQml 2.15 after any QtQuick imports and set
the restoreMode of the binding to fix this warning.
In Qt < 6.0 the default is Binding.RestoreBinding.
In Qt >= 6.0 the default is Binding.RestoreBindingOrValue.
QQmlEngine::setContextForObject(): Object already has a QQmlContext
kf.kirigami: Units.devicePixelRatio is deprecated (since 5.86 ): This returns 1 when using Qt HiDPI scaling.
I allready tried by resetting all configs via garuda assistant but did not helped.
inxi -Faz
inxi -Faz
System:    Kernel: 5.14.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=c7830645-81ec-4575-b78e-6054ff59983c
systemd.unified_cgroup_hierarchy=1 resume=UUID=c1d80959-5bb6-44ff-9bff-7d85ab6c3145 loglevel=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Laptop System: Acer product: Aspire A515-44 v: V1.12 serial: <filter>
Mobo: RO model: Calla_RN v: V1.12 serial: <filter> UEFI: INSYDE v: 1.12 date: 03/15/2021
Battery:   ID-1: BAT1 charge: 23.0 Wh (51.8%) condition: 44.4/53.0 Wh (83.8%) volts: 16.1 min: 15.4
model: PANASONIC AP19B5L type: Li-ion serial: <filter> status: Charging
CPU:       Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP arch: Zen 2
family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600103 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31943
Speed: 1540 MHz min/max: 1400/2000 MHz boost: disabled Core speeds (MHz): 1: 1540 2: 1760
3: 1463 4: 1556 5: 1349 6: 1694 7: 1489 8: 1659
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics:  Device-1: AMD Renoir vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus-ID: 05:00.0
Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-4:2 chip-ID: 0408:a061
class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
Screen-1: 0 s-res: 1920x1080 s-dpi: 142 s-size: 344x193mm (13.5x7.6") s-diag: 394mm (15.5")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.16-zen1-1-zen LLVM 12.0.1) v: 4.6 Mesa 21.2.4
direct render: Yes
Audio:     Device-1: AMD vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 05:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Acer Incorporated ALI
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.14.16-zen1-1-zen running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI
driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Lite-On
driver: ath10k_pci v: kernel bus-ID: 04:00.0 chip-ID: 168c:003e class-ID: 0280
Bluetooth: Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-3:2 chip-ID: 04ca:3016
Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter>
Drives:    Local Storage: total: 942.7 GiB used: 222.56 GiB (23.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520 SDAPNUW-512G-1014
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 20110000 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LM000-SSHD-8GB size: 465.76 GiB
serial: <filter> rev: LVD3 scheme: GPT
Partition: ID-1: / raw-size: 467.88 GiB size: 467.88 GiB (100.00%) used: 222.56 GiB (47.6%) fs: btrfs
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 547 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 467.88 GiB size: 467.88 GiB (100.00%) used: 222.56 GiB (47.6%) fs: btrfs
ID-4: /var/log raw-size: 467.88 GiB size: 467.88 GiB (100.00%) used: 222.56 GiB (47.6%)
ID-5: /var/tmp raw-size: 467.88 GiB size: 467.88 GiB (100.00%) used: 222.56 GiB (47.6%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
maj-min: 259:3
ID-2: swap-2 type: zram size: 18.92 GiB used: 768 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 52.1 C mobo: 52.0 C gpu: amdgpu temp: 50.0 C
Info:      Processes: 324 Uptime: 7m wakeups: 1 Memory: 18.92 GiB used: 3.42 GiB (18.1%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1962 pacman: 1954
lib: 485 snap: 8 Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.08
Disd you search in forum?
latte-dock?
@SGS ah thank you so its a problem with the xorg server?
Searched for forum latte-dock but didn´t found something similar.
Having the same issue, HUGE windows, some apps i can not even see as they are off my 2k screen...I moved to linux to get away from random issues happening after a patch cycle....Processing: IMG_0634.JPG...
This topic has been solved.
Did the posted solution not work for you?
