Hello! After I updated my operating system(Garuda Linux Dragonized) if I unplug my laptop charger and I power on my laptop, after the loading bar is half, the screen is turning black and is blinking. If I set in optimus manager Startup mode to Hybrid or Integrated it will start, but it will be very laggy. I don't have auto-cpufreq or other powersave tweaks.
System: Kernel: 5.14.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=0ac31f06-34e0-40f3-84f5-926dfafc21fe
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: TUF Gaming FX505DU_FX505DU v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FX505DU v: 1.0 serial: <filter> UEFI-[Legacy]: American Megatrends
v: FX505DU.316 date: 01/28/2021
Battery: ID-1: BAT0 charge: 32.1 Wh (91.5%) condition: 35.1/48.1 Wh (73.1%) volts: 12.7 min: 11.7
model: FX50442 type: Li-ion serial: N/A status: Charging
CPU: Info: Quad Core model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx bits: 64 type: MT MCP
arch: Zen family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108102 cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 36727
Speed: 2555 MHz min/max: 1400/2300 MHz boost: enabled Core speeds (MHz): 1: 2555 2: 2609
3: 1805 4: 2637 5: 3179 6: 2943 7: 1177 8: 1245
Graphics: Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus-ID: 5-1:2
chip-ID: 13d3:56e5 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: modesetting,nvidia
Monitor-1: eDP-1-1 res: 1920x1080 hz: 120 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44
direct render: Yes
Audio: Device-1: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.14.16-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: AzureWave
driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: d000 bus-ID: 04:00.0 chip-ID: 10ec:c822
Bluetooth: Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 3-4:2
chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
Drives: Local Storage: total: 1.38 TiB used: 52.18 GiB (3.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB
rev: 002C temp: 36.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172 size: 931.51 GiB
serial: <filter> rev: SDM1 scheme: GPT
Partition: ID-1: / raw-size: 476.93 GiB size: 476.93 GiB (100.00%) used: 32.81 GiB (6.9%) fs: btrfs
ID-2: /home raw-size: 476.93 GiB size: 476.93 GiB (100.00%) used: 32.81 GiB (6.9%) fs: btrfs
ID-3: /var/log raw-size: 476.93 GiB size: 476.93 GiB (100.00%) used: 32.81 GiB (6.9%) fs: btrfs
ID-4: /var/tmp raw-size: 476.93 GiB size: 476.93 GiB (100.00%) used: 32.81 GiB (6.9%) fs: btrfs
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 86.4 C mobo: N/A
Fan Speeds (RPM): cpu: 4500
GPU: device: nvidia screen: :0.0 temp: 56 C device: amdgpu temp: 86.0 C
Info: Processes: 358 Uptime: 42m wakeups: 1 Memory: 15.06 GiB used: 5.45 GiB (36.2%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1428 lib: 349
