Laptop won't charge with USB-C
  Kernel: 5.15.13-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=113673ed-5df1-43fd-8db4-c2db9f724f03 rw [email protected]
    resume=UUID=29954f21-5583-407d-82bc-ce5dd6c30d3f loglevel=3
  Type: Laptop System: LENOVO product: 82L5 v: IdeaPad 5 Pro 16ACH6
    serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 Pro 16ACH6
  Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
    serial: <superuser required> UEFI: LENOVO v: GSCN27WW date: 08/23/2021
  ID-1: BAT0 charge: 73.3 Wh (97.7%) condition: 75.0/75.0 Wh (100.0%)
    volts: 17.1 min: 15.4 model: LGC L20L4PE1 type: Li-ion serial: <filter>
    status: Discharging cycles: 4
    arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
    microcode: 0xA50000C
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1424 high: 1840 min/max: 1200/3200 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 1397 2: 1396
    3: 1397 4: 1397 5: 1840 6: 1397 7: 1397 8: 1397 9: 1397 10: 1396 11: 1397
    12: 1397 13: 1396 14: 1397 15: 1397 16: 1396 bogomips: 102232
    IBRS_FW, STIBP: always-on, RSB filling
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
    driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
    chip-ID: 10de:1f9d class-ID: 0302
  Device-2: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel
    bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300
  Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
    bus-ID: 3-4:3 chip-ID: 13d3:56fb class-ID: fe01 serial: <filter>
    loaded: modesetting,nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.7x16.7")
    s-diag: 798mm (31.4")
  Monitor-1: eDP-1 res: 2560x1600 hz: 60 dpi: 189
    size: 344x215mm (13.5x8.5") diag: 406mm (16")
  Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel
    bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
    vendor: Lenovo driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 05:00.5
  Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.13-arch1-1 running: yes
  Sound Server-4: PipeWire v: 0.3.43 running: yes
  Device-1: MEDIATEK vendor: Lenovo driver: mt7921e v: kernel port: N/A
    bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
  Device-1: Foxconn / Hon Hai Wireless_Device type: USB driver: btusb v: 0.8
    bus-ID: 3-3:2 chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
  Local Storage: total: 476.94 GiB used: 48.06 GiB (10.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GDE9X084N
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41010C22
    temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 461.82 GiB size: 461.82 GiB (100.00%)
    used: 48.06 GiB (10.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 461.82 GiB size: 461.82 GiB (100.00%)
  ID-4: /var/log raw-size: 461.82 GiB size: 461.82 GiB (100.00%)
  ID-5: /var/tmp raw-size: 461.82 GiB size: 461.82 GiB (100.00%)
  ID-1: swap-1 type: partition size: 14.86 GiB used: 0 KiB (0.0%)
  ID-2: swap-2 type: zram size: 13.57 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 20.0 C mobo: N/A gpu: amdgpu temp: 42.0 C
  Processes: 413 Uptime: 3m wakeups: 551 Memory: 13.57 GiB
  used: 2.54 GiB (18.7%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1464 lib: 350 Shell: fish
  v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.11
Problem is fairly simple, when I bought my new laptop and tested USB-C charging on windows it worked fine, not quick but it worked. It won't work on Linux with the same cable.
I have tries various cables, low voltage, regular chargers and the one I tried with Windows was a OnePlus Warp Charger which worked great, but it won't work on garuda, maybe I'm missing some Usb power delivery modules?
Is it supposed to support charging the laptop using USB-C?
Oh, yes:
So - the laptop doesn't charge at all, even using the included power adapter?
I would recommend testing at least 3 alternate kernels, making sure that your bios is up to date, and testing the linux-firmware-git package.
Good luck
Also did you install any power saving utilities, like TLP for example.
That is your problem the Lenavo was designed for use on windows not Linux contact Lenavo they will probally tell you its does not support Linux :hearts: :grinning_face_with_smiling_eyes: Plus their tablets are very dodgy charging with USB-C it took 3 replacements to get it to charge.
Try enabling Rapid Charge as per the Arch Wiki entry for Lenovo IdeaPad 5
This one didn't work unfortunately.
I tried linux, linux-zen and linux-lts. Such a strange issue, althought I might have to give up on it soon.
This doesn't help.
However, the linux-firmware-git package instead of the regular linux-firmware solved the issue. I also installed slimbookbattery so not sure if that has something to do with it, but hey thank you.
When you have used Linux a few years you will understand "what i said was tongue in cheek"
Every problem Linux related is thrown out with the words "we don't support Linux" everything from a USB stick to a system is only supported for Windows read the disclaimers.
