Hey all,
I made a fresh install of Garuda KDE version. But this time i have a problem with the language... Part of the system is in french and part is in englsih...
It seems like all is set with fr_CH.utf8, but...
What am i doing wrong ?
Here's my inxi
Kernel: 6.0.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=5a2ed686-9f3f-4d1c-a51e-41bbeea7c18c
rw [email protected] quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: LENOVO product: 20FRS08T00 v: ThinkPad X1 Carbon 4th
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: LENOVO model: 20FRS08T00 v: SDK0J40697 WIN serial: <superuser required> UEFI: LENOVO
v: N1FET80W (1.54 ) date: 07/29/2022
ID-1: BAT0 charge: 45.3 Wh (95.4%) condition: 47.5/52.1 Wh (91.2%) volts: 16.2 min: 15.2
model: SMP 00HW029 type: Li-poly serial: <filter> status: not charging
Device-1: wacom_battery_0 model: Wacom Pen and multitouch sensor serial: N/A charge: 0%
rechargeable: yes status: N/A
Info: model: Intel Core i7-6600U bits: 64 type: MT MCP arch: Skylake gen: core 6 level: v3
note: check built: 2015 process: Intel 14nm family: 6 model-id: 0x4E (78) stepping: 3
microcode: 0xF0
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3282 high: 3376 min/max: 400/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 3355 2: 3200 3: 3376 4: 3200 bogomips: 22399
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915 v: kernel arch: Gen-9
process: Intel 14n built: 2015-16 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:5 chip-ID: 04f2:b531
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.5 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: LG Display 0x04aa built: 2015 res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2
size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 520 (SKL GT2)
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound API: ALSA v: k6.0.10-zen2-1-zen running: yes
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
Device-1: Intel Bluetooth wireless interface type: USB driver: btu
sb v: 0.8 bus-ID: 1-7:4
chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 462.07 GiB used: 84.92 GiB (18.4%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: 00000 size: 238.5 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSCKGF240A5L size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: LV8i scheme: GPT
ID-1: / raw-size: 58.11 GiB size: 58.11 GiB (100.00%) used: 11.12 GiB (19.1%) fs: btrfs
dev: /dev/sda6 maj-min: 8:6
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%) used: 612 KiB (0.1%) fs: vfat
dev: /dev/sda5 maj-min: 8:5
ID-3: /home raw-size: 58.11 GiB size: 58.11 GiB (100.00%) used: 11.12 GiB (19.1%) fs: btrfs
ID-4: /var/log raw-size: 58.11 GiB size: 58.11 GiB (100.00%) used: 11.12 GiB (19.1%) fs: btrfs
ID-5: /var/tmp raw-size: 58.11 GiB size: 58.11 GiB (100.00%) used: 11.12 GiB (19.1%) fs: btrfs
ID-1: swap-1 type: zram size: 7.62 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 37.0 C pch: 37.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 220 Uptime: 46m wakeups: 3 Memory: 7.62 GiB used: 3.18 GiB (41.7%) Init: systemd
v: 252 default: graphical tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1330
libs: 364 tools: octopi,paru Client: shell wrapper v: 5.1.16-release inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2022-12-02
Last full system update: 2022-12-03
Here's my locale -a
C
C.UTF-8
en_US.utf8
fr_CH.utf8
POSIX
It must be so simple, that i cant find the solution by myself
