Lag Issues
I recently switched to garuda dragonized kde from windows and I’ve had some minor issues with getting everything setup which I figured out by looking it up, there are things I couldn’t find the answer to.
  1. discord seems to lag but only while typing and only the app on browser it perfectly fine.
  2. no matter how much i mess with in game setting every game seems to stutter even the ones that have a linux version not just the ones on steam ran through proton.
You should provide
Because this sounds like you have NVIDIA and run Wayland, if yes switch to X11. These issues you describe are common problems currently when using Wayland with NVIDIA GPUs.
Regards,
S.
