I have just installed Garuda Dragonized on an old Intel Core 2 Quad system that used to be my Windows 7/10 system. Booting the system from USB ran fine and the install did not report any problems. The initial screen comes up and looks great. I can log in and all is fine. As soon as I start any graphical process, such as RANI, the system bogs down massively, the mouse stutters and jumps, and the keyboard respose is slow and often repeats a key multiple times.
I installed and started the ssh daemon and loging in from my other PC, a top command shows kwin_wayland using >300% CPU!
Since this is using an nvidia GTX 970, Iām guessing that there is a driver issue, however, I have not been able to figure out how to properly change the driver in use. Since this was just installed, if Iāve messed up the system attempting to follow instructions from various other nvidia posts, Iāll happily start over, but the issue has not changed with the attempts Iāve tried thus far to change the drivers.
Kernel: 6.18.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1 clocksource: tsc
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=b3469527-a2f7-4aab-b4d7-720d1e48a6a8
rw rootflags=subvol=@ quiet loglevel=3
Console: pty pts/1 DM: SDDM Distro: Garuda base: Arch Linux
Type: Desktop Mobo: MSI model: MS-7320 v: 1.0 serial: N/A Firmware: BIOS
vendor: American Megatrends v: 1.3 date: 11/02/2007
Info: model: Intel Core2 Quad Q6600 bits: 64 type: MCP arch: Core2 Merom level: v1
built: 2006-09 process: Intel 65nm family: 6 model-id: 0xF (15) stepping: 0xB (11)
microcode: 0xBA
Topology: cpus: 1x dies: 1 clusters: 2 cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 2400 min/max: N/A base/boost: 2403/2400 volts: 1.3 V ext-clock: 267 MHz
cores: 1: 2400 2: 2400 3: 2400 4: 2400 bogomips: 19197
Flags-basic: ht lm nx pae sse sse2 sse3 ssse3 vmx
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: PNY driver: nvidia v: 580.119.02
alternate: nouveau,nvidia_drm non-free: 550-580.xx+ status: current (as of 2025-11;
EOL~2026-12-xx) arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-2019 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:13c2
Display: unspecified server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9
compositor: kwin_wayland driver: X: loaded: modesetting,nouveau alternate: fbdev,nv,vesa
gpu: nvidia tty: 100x51
Monitor-1: Unknown-1 size-res: N/A in console modes: 1680x1050
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 1 drv: swrast
surfaceless: drv: nvidia inactive: gbm,wayland,x11
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 25.3.2-arch1.1 note: console (EGL sourced)
renderer: NVIDIA GeForce GTX 970/PCIe/SSE2, llvmpipe (LLVM 21.1.6 128 bits)
API: Vulkan v: 1.4.335 layers: 12 device: 0 type: discrete-gpu name: NVIDIA GeForce GTX 970
driver: nvidia v: 580.119.02 device-ID: 10de:13c2 surfaces: N/A device: 1 type: cpu
name: llvmpipe (LLVM 21.1.6 128 bits) driver: mesa llvmpipe v: 25.3.2-arch1.1 (LLVM 21.1.6)
gpu: corectrl,nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA GM204 High Definition Audio vendor: PNY driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 10de:0fbb class-ID: 0403
Device-2: ASUSTek Xonar SoundCard driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 0b05:189d class-ID: 0300
API: ALSA v: k6.18.2-zen2-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 1.4.9 status: n/a (root, process) with: 1: pipewire-pulse status: active
Device-1: NVIDIA MCP55 Ethernet vendor: Micro-Star MSI type: network bridge driver: forcedeth
v: kernel modules: nvidia_drm,nvidia port: 9080 bus-ID: 00:11.0 chip-ID: 10de:0373
class-ID: 0680
IF: enp0s17 state: down mac: <filter>
Device-2: NVIDIA MCP55 Ethernet vendor: Micro-Star MSI type: network bridge driver: forcedeth
v: kernel modules: nvidia_drm,nvidia port: 9000 bus-ID: 00:12.0 chip-ID: 10de:0373
class-ID: 0680
IF: enp0s18 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 953.94 GiB used: 25.33 GiB (2.7%)
ID-1: /dev/sdb maj-min: 8:16 vendor: EDGE Tech model: E3 SSD size: 465.76 GiB block-size:
physical: 512 B logical: 512 B sata: 3.1 speed: 3.0 Gb/s tech: SSD serial: <filter> fw-rev: 7C
temp: 26 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 29 hrs cycles: 72 read: 19.6 MiB
written: 28.6 MiB
ID-2: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SSD U100 16GB family: based SSDs
size: 14.91 GiB block-size: physical: 512 B logical: 512 B sata: 3.0 speed: 3.0 Gb/s tech: SSD
serial: <filter> fw-rev: 6.14 scheme: MBR
SMART: yes state: enabled health: PASSED on: 139d 23h cycles: 537 read: 15.48 GiB
written: 17.39 GiB
ID-3: /dev/sdd maj-min: 8:48 vendor: Hitachi model: HDP725050GLA360 family: Deskstar P7K500
size: 465.76 GiB block-size: physical: 512 B logical: 512 B sata: 2.6 speed: 3.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: A52A temp: 25 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 7y 134d 0h cycles: 2272
ID-4: /dev/sde maj-min: 8:64 vendor: SMI (STMicroelectronics) model: USB size: 7.5 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: N/A serial: <filter> fw-rev: 1100 scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 22 GiB (4.7%) fs: btrfs
block-size: 4096 B dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 3.26 GiB (0.7%) fs: btrfs
block-size: 4096 B dev: /dev/sdd1 maj-min: 8:49
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 22 GiB (4.7%) fs: btrfs
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 22 GiB (4.7%) fs: btrfs
ID-1: swap-1 type: zram size: 7.75 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
ID-2: swap-2 type: partition size: 14.91 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdc1
maj-min: 8:33
System Temperatures: cpu: 49.0 C mobo: N/A
Memory: total: 8 GiB available: 7.75 GiB used: 2.73 GiB (35.2%)
Processes: 301 Power: uptime: 24m states: freeze,mem,disk suspend: s2idle wakeups: 0
hibernate: shutdown avail: reboot,suspend,test_resume image: 3.02 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 259
Packages: pm: pacman pkgs: 1879 libs: 519 tools: gnome-software,octopi,paru pm: flatpak
pkgs: 0 Compilers: gcc: 15.2.1 Shell: Bash (sudo) v: 5.3.9 running-in: pty pts/1 (SSH)
inxi: 3.3.40
Garuda (2.11.1-1):
System install date: 2025-12-27
Garuda release: 251103
Last full system update: 2025-12-29 ā»
Relevant software: snapper NetworkManager dracut nvidia-580xx-dkms garuda-hardware-profile-nvidia-580xx garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
25/26 checks run in 1.64 seconds ā
Powered by garuda-health š¦
--- CRITICAL ---
- SMART status for /dev/sda is failing
--- INFO ---
Top of the ātopā run with 3 windows open on the primary display:
top - 16:40:45 up 23 min, 2 users, load average: 4.50, 2.82, 1.47
Tasks: 304 total, 1 running, 303 sleep, 0 d-sleep, 0 stopped, 0 zombie
%Cpu(s): 93.8 us, 1.4 sy, 0.2 ni, 4.0 id, 0.0 wa, 0.5 hi, 0.1 si, 0.0 st
MiB Mem : 7933.1 total, 2462.2 free, 2849.6 used, 3054.9 buff/cache
MiB Swap: 23204.0 total, 23204.0 free, 0.0 used. 5083.5 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
70908 larry -2 -12 1676020 592508 360980 S 374.6 7.3 10:03.47 kwin_wayland
71091 larry 19 -1 3357332 936076 412396 S 2.3 11.5 0:33.03 plasmashell
76438 root 20 0 0 0 0 I 2.3 0.0 0:00.95 kworker/u18:9-events_unbound
78725 larry 36 16 11184 7916 5664 R 0.7 0.1 0:00.03 top
71337 larry 36 16 1380948 317992 269336 S 0.3 3.9 0:01.36 kdeconnectd
1 root 20 0 24040 14632 9784 S 0.0 0.2 0:03.90 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.01 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 0:00.00 pool_workqueue_release
Not sure if this is helpful, but in the interest of supplying anything that might help, here is the output from the nvidia-smi command:
Mon Dec 29 17:43:38 2025
| NVIDIA-SMI 580.119.02 Driver Version: 580.119.02 CUDA Version: 13.0 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce GTX 970 Off | 00000000:01:00.0 Off | N/A |
| 22% 30C P8 20W / 151W | 0MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
I hope this isnāt something totally stupid that Iāve done. Iām much more familiar with Red Hat Enterprise and donāt normally have any interest in graphics/gaming. But Iām hoping to try to install & run a Windows ERP client under Linux as a way to replace a bunch of Windows 10 PCs that wonāt upgrade to Windows 11 but are othersize just fine for the office workers. If all goes well, Iāll also try to do some limited gaming on this machine here at home.
