Hello everyone,
Kwin seems to be stuck on 60 fps which causes lag during animations. I have a laptop with a GTX 1650 4GB, and its drivers are picked up fine as I can run benchmarks and even play games just fine. But it's Kwin that seems to be the problem.
I actually had the same issue with my desktop, and it was only (indirectly) fixed by buying a high refresh rate monitor (144hz), now Kwin is stuck at 144 which is plenty but still very strange.
Obviously, my laptop is 60hz. I have tried setting certain environment variables:
- KWIN_COMPOSITE
- I have set maxfps on .kwinrc and nothing.
I have TripleBufferOn
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=113673ed-5df1-43fd-8db4-c2db9f724f03 rw rootflags=subvol=@
resume=UUID=29954f21-5583-407d-82bc-ce5dd6c30d3f loglevel=3
Type: Laptop System: LENOVO product: 82L5 v: IdeaPad 5 Pro 16ACH6
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 Pro 16ACH6
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> UEFI: LENOVO v: GSCN27WW date: 08/23/2021
ID-1: BAT0 charge: 65.1 Wh (86.8%) condition: 75.0/75.0 Wh (100.0%)
volts: 16.5 min: 15.4 model: LGC L20L4PE1 type: Li-ion serial: <filter>
status: Discharging
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1864 high: 2917 min/max: 1200/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2240 2: 1397
3: 1640 4: 1395 5: 1958 6: 1396 7: 1395 8: 2194 9: 2419 10: 1593 11: 2792
12: 1635 13: 1759 14: 2917 15: 1394 16: 1706 bogomips: 102208
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f9d class-ID: 0302
Device-2: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-4:3 chip-ID: 13d3:56fb class-ID: fe01 serial: <filter>
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.7x16.7")
s-diag: 798mm (31.4")
Monitor-1: eDP-1-1 res: 2560x1600 hz: 60 dpi: 189
size: 344x215mm (13.5x8.5") diag: 406mm (16")
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 05:00.5
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
Device-1: MEDIATEK vendor: Lenovo driver: mt7921e v: kernel port: N/A
bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: Foxconn / Hon Hai Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-3:2 chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 21.31 GiB (4.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GDE9X084N
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41010C22
temp: 39.9 C scheme: GPT
ID-1: / raw-size: 461.82 GiB size: 461.82 GiB (100.00%)
used: 21.31 GiB (4.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 461.82 GiB size: 461.82 GiB (100.00%)
ID-4: /var/log raw-size: 461.82 GiB size: 461.82 GiB (100.00%)
ID-5: /var/tmp raw-size: 461.82 GiB size: 461.82 GiB (100.00%)
ID-1: swap-1 type: partition size: 14.86 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 13.57 GiB used: 1024 KiB (0.0%)
System Temperatures: cpu: 20.0 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 46 C device: amdgpu temp: 43.0 C
Processes: 439 Uptime: 5m wakeups: 432 Memory: 13.57 GiB
used: 2.78 GiB (20.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1274 lib: 304 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
