Launching Konsole produces the following error
exec: Failed to execute process: '/usr/bin/konsole' the file could not be run by the operating system.
Kernel: 6.1.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=59a5503e-fcee-4e1c-8787-e3f6172b5eaa rw [email protected]
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Type: Laptop System: LENOVO product: 80XH v: Lenovo ideapad 320-15ISK
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 320-15ISK
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI-[Legacy]: LENOVO v: 4WCN37WW date: 12/04/2017
ID-1: BAT0 charge: 7.0 Wh (43.5%) condition: 16.1/30.0 Wh (53.6%) volts: 7.8
min: 7.4 model: LGC L16L2PB2 type: Li-poly serial: <filter> status: charging
Info: model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2000 min/max: 400/2000 scaling: driver: intel_pstate
governor: powersave cores: 1: 2000 2: 2000 3: 2000 4: 2000 bogomips: 15999
Device-1: Intel HD Graphics 520 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1921 class-ID: 0300
Device-2: Syntek EasyCamera type: USB driver: uvcvideo bus-ID: 1-8:4
chip-ID: 174f:241a class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa dri: i965 gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: eDP-1 mapped: eDP1 model: BOE Display 0x0729 built: 2017
res: 1920x1080 hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
API: OpenGL v: 4.6 Mesa 22.3.2 renderer: Mesa Intel HD Graphics 520 (SKL
GT2) direct render: Yes
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound API: ALSA v: k6.1.1-zen1-1-zen running: yes
port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:3166 class-ID: 0280
bus-ID: 1-7:3 chip-ID: 8087:0a2a class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 7 state: down
address: <filter>
Local Storage: total: 931.51 GiB used: 566.26 GiB (60.8%)
model: WD10SPZX-24Z10T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
ID-1: / raw-size: 589.23 GiB size: 589.23 GiB (100.00%)
used: 566.26 GiB (96.1%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /home raw-size: 589.23 GiB size: 589.23 GiB (100.00%)
ID-3: /var/log raw-size: 589.23 GiB size: 589.23 GiB (100.00%)
ID-4: /var/tmp raw-size: 589.23 GiB size: 589.23 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.47 GiB used: 1.81 GiB (15.8%)
System Temperatures: cpu: 46.0 C pch: 47.0 C mobo: N/A
Processes: 270 Uptime: 4d 16h 17m wakeups: 25098 Memory: 11.47 GiB
used: 3.96 GiB (34.6%) Init: systemd v: 252 default: graphical
pkgs: 2260 libs: 543 tools: pamac,paru Shell: fish v: 3.5.1
running-in: termius-app inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2021-05-31
Last full system update: 2023-01-07 ↻
Relevant software: timeshift NetworkManager mkinitcpio
Windows dual boot: Yes/Detected
Failed units: [email protected] systemd-vconsole-setup.service
