kImageAnnotator installed but not ksnip?
i noticed that the package kimageannotator is installed by default with Garuda. But from what I can tell, you can 't run it on it's own, it's a part of ksnip?
But then ksnip isn't installed by default?
  Kernel: 6.3.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=f421b3e9-feb7-49ce-885d-088d8fed2dde rw rootflags=subvol=@
    loglevel=3 module_blacklist=hid_sensor_hub nvme.noacpi=1 ibt=off
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_wayland vt: 2
  Type: Laptop System: Framework product: Laptop (12th Gen Intel Core) v: A4
  Mobo: Framework model: FRANMACP04 v: A4 serial: <superuser required>
    UEFI: INSYDE v: 03.05 date: 08/23/2022
  ID-1: BAT1 charge: 20.3 Wh (37.2%) condition: 54.6/55.0 Wh (99.2%)
    volts: 15.6 min: 15.4 model: NVT Framewo type: Li-ion serial: <filter>
    status: charging cycles: 31
  Device-1: hidpp_battery_2 model: Logitech Wireless Mouse MX Master
  Info: model: 12th Gen Intel Core i5-1240P bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    microcode: 0x42A
  Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
    cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
    L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 2108 high: 2975 min/max: 400/4400:3300 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2975 2: 2100 3: 2531
    4: 2100 5: 2869 6: 2100 7: 1597 8: 2100 9: 2896 10: 2081 11: 2360 12: 2100
    13: 2387 14: 851 15: 421 16: 2273 bogomips: 67584
  Device-1: Intel Alder Lake-P Integrated Graphics driver: i915 v: kernel
    arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0 chip-ID: 8086:46a6
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
  Monitor-1: eDP-1 res: 2256x1504 size: N/A modes: N/A
  API: OpenGL v: 4.6 Mesa 23.1.1 renderer: Mesa Intel Graphics (ADL GT2)
    direct-render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio driver: snd_hda_intel
    chip-ID: 8086:51c8 class-ID: 0403
  API: ALSA v: k6.3.4-zen1-1-zen status: kernel-api tools: N/A
    pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: a6:00.0 chip-ID: 8086:2725
  IF: wlp166s0 state: up mac: <filter>
  IF-ID-2: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0032
  Local Storage: total: 1.82 TiB used: 408.7 GiB (21.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 49.9 C
  ID-1: / raw-size: 177.08 GiB size: 177.08 GiB (100.00%)
    used: 158.98 GiB (89.8%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 576 KiB (0.0%)
    fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 177.08 GiB size: 177.08 GiB (100.00%)
  ID-4: /var/log raw-size: 177.08 GiB size: 177.08 GiB (100.00%)
  ID-5: /var/tmp raw-size: 177.08 GiB size: 177.08 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.06 GiB used: 20.79 GiB (66.9%)
  System Temperatures: cpu: 66.0 C mobo: N/A
  Processes: 538 Uptime: 1d 41m wakeups: 56311 Memory: available: 31.06 GiB
  used: 24.07 GiB (77.5%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 2005
  pm: pacman pkgs: 1996 libs: 432 tools: gnome-software,octopi,pamac,paru
  pm: rpm pkgs: 0 pm: flatpak pkgs: 9 Shell: fish v: 3.6.1 default: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.27
  System install date:     2023-05-04
  Last full system update: 2023-05-29 ↻
It is Ksnip which depends on Kimageannotator:
pacman -Sii kimageannotator
Repository      : extra
Version         : 0.6.1-1
Description     : Tool for annotating images
Architecture    : x86_64
URL             : https://github.com/ksnip/kImageAnnotator
Licenses        : GPL
Groups          : None
Provides        : None
Depends On      : qt5-svg  kcolorpicker
Optional Deps   : None
Required By     : gwenview  ksnip
pacman -Sii ksnip
Repository      : extra
Version         : 1.10.1-1
Description     : Qt-based screenshot tool that provides many annotation features
URL             : https://github.com/ksnip/ksnip
Licenses        : GPL2
Groups          : None
Provides        : None
Depends On      : hicolor-icon-theme  kimageannotator  qt5-x11extras
My guess would be an effort was made to simplify the package base, and cutting back to one screenshotting tool seems reasonable but probably Spectacle was chosen for this reason or that.
This is off-topic, but I started using Ksnip on my Sway installations when Flameshot became super unreliable on wlroots machines:
for_window [app_id=org.ksnip.ksnip] floating enable, resize set 60ppt 75ppt|
bindsym print exec grim -g $(slurp) Pictures/screenshots/$(date +'ss_%m-%d-%y-%H%M%S.png') && exec ksnip -e Pictures/screenshots/$(date +'ss_%m-%d-%y-%H%M%S.png')|
Grim and Slurp take the screenshot and pass the image to Ksnip for annotation. A little hacky perhaps, but it works great!
Edit:
I realized I didn’t really respond to this:
You don’t run it on its own, but it can be used with other applications besides Ksnip. Here is an example of a thread where they made some development choices with Spectacle in mind:
