Keychain not unlocked
hi I have a problem every time I start visual studio code I get this message "the login keychain was not unlocked when you logged or to this computer" and I have to enter the password and since it didn't happen before but it happens for some time I wanted to ask if there is a particular reason why this happens and if there is a solution. Thanks in advance
I don't know if this can help... just a quick search on the web:
Someone seemed to solve it by " Deleting the old vscode-github.login from Keychain Access"
Did you log in with your password? If not, the default keyring will need to be unlocked when it is first accessed.
Otherwise, have you changed your password recently? If so, you'll have to update the keyring password to match so it can be unlocked when you log in.
