Keybord language and layout resets every couple of seconds
Mostly header has an explanation, but let me explain what happens:
I added 1 more language to keyboard set (It is Ukrainian), and I noticed that every ~10 seconds language resets to English… even when doing absolutely nothing…
I noticed that it resets even on English (like keyboard control app is restarting) because it misses a button press on that particular second of reset…
What i need to do?
Output of sudo garuda-inxi:
  Kernel: 6.6.1-zen1-1-zen arch: x86_64
    bits: 64 compiler: gcc v: 13.2.1
    root=UUID=b54eda9c-988d-4ae2-8df4-5f891562df36
    rw rootflags=subvol=@ quiet quiet
    rd.udev.log_priority=3
    vt.global_cursor_default=0 loglevel=3
  Desktop: KDE Plasma v: 5.27.9 tk: Qt
    v: 5.15.11 wm: kwin_x11 dm: SDDM
  Type: Laptop System: ASUSTeK
    product: ROG Strix G712LW_G712LW v: 1.0
  Mobo: ASUSTeK model: G712LW v: 1.0
    serial: <filter> UEFI: American Megatrends
    v: G712LW.314 date: 04/27/2021
  ID-1: BAT0 charge: 52.8 Wh (96.0%)
    condition: 55.0/66.0 Wh (83.3%)
    volts: 15.7 min: 15.7
    model: ASUSTeK ASUS Battery type: Li-ion
    serial: N/A status: not charging
    cycles: 99
  Info: model: Intel Core i7-10750H
    socket: U3E1 bits: 64 type: MT MCP
    arch: Comet Lake gen: core 10 level: v3
    note: check built: 2020
    process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 2
    microcode: 0xF8
  Topology: cpus: 1x cores: 6 tpc: 2
    threads: 12 smt: enabled cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB
    L2: 1.5 MiB desc: 6x256 KiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 3125 high: 3201
    min/max: 800/5000 base/boost: 2574/8300
    scaling: driver: intel_pstate
    governor: powersave volts: 0.8 V
    ext-clock: 100 MHz cores: 1: 3200
    2: 3200 3: 3201 4: 3118 5: 3200 6: 3201
    7: 3200 8: 3200 9: 3201 10: 3192
    11: 3200 12: 2397 bogomips: 62399
  Flags: avx avx2 ht lm nx pae sse sse2
    sse3 sse4_1 sse4_2 ssse3 vmx
  Device-1: Intel CometLake-H GT2 [UHD
    Graphics] vendor: ASUSTeK driver: i915
    v: kernel arch: Gen-9.5
    process: Intel 14nm built: 2016-20
    ports: active: eDP-1 empty: none
    bus-ID: 00:02.0 chip-ID: 8086:9bc4
  Device-2: NVIDIA TU106M [GeForce RTX
    2070 Mobile / Max-Q Refresh]
    vendor: ASUSTeK driver: nvidia
    v: 545.29.02
    alternate: nouveau,nvidia_drm
    non-free: 545.xx+ status: current (as
    of 2023-10; EOL~2026-12-xx) arch: Turing
    code: TUxxx process: TSMC 12nm FF
    built: 2018-2022 pcie: gen: 1
    speed: 2.5 GT/s lanes: 8 link-max:
    gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1f14
  Display: server: X.Org v: 21.1.9
    with: Xwayland v: 23.2.2
    compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia
    unloaded: nouveau
    alternate: fbdev,intel,nv,vesa dri: iris
  Screen-1: 0 s-res: 2944x1080 s-dpi: 96
    s-size: 776x285mm (30.55x11.22")
    s-diag: 827mm (32.55")
  Monitor-1: HDMI-1-0 pos: bottom-r
    res: 1024x600 hz: 60 dpi: 102
    size: 255x255mm (10.04x10.04")
    diag: 361mm (14.2") modes: N/A
  Monitor-2: eDP-1 pos: primary,top-left
    res: 1920x1080 hz: 144 dpi: 128
    size: 382x215mm (15.04x8.46")
    diag: 438mm (17.26") modes: N/A
  API: EGL v: 1.5 hw: drv: intel iris
    drv: nvidia platforms: device: 0
    drv: nvidia device: 1 drv: iris
    device: 3 drv: swrast gbm:
    drv: kms_swrast surfaceless: drv: nvidia
    x11: drv: iris
    inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5
    vendor: intel mesa v: 23.2.1-arch1.2
    glx-v: 1.4 direct-render: yes
    renderer: Mesa Intel UHD Graphics (CML
    GT2) device-ID: 8086:9bc4
    memory: 30.41 GiB unified: yes
  API: Vulkan v: 1.3.269 layers: 4
    device: 0 type: integrated-gpu name: Intel
    UHD Graphics (CML GT2)
    driver: mesa intel v: 23.2.1-arch1.2
    device-ID: 8086:9bc4 surfaces: xcb,xlib
    device: 1 type: discrete-gpu
    name: NVIDIA GeForce RTX 2070
    driver: nvidia v: 545.29.02
    device-ID: 10de:1f14 surfaces: xcb,xlib
    device: 2 type: cpu name: llvmpipe
    (LLVM 16.0.6 256 bits)
    driver: mesa llvmpipe v: 23.2.1-arch1.2
    (LLVM 16.0.6) device-ID: 10005:0000
    surfaces: xcb,xlib
  Device-1: Intel Comet Lake PCH cAVS
    vendor: ASUSTeK driver: snd_hda_intel
    v: kernel
    alternate: snd_soc_skl,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:06c8
  Device-2: NVIDIA TU106 High Definition
    Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 8 link-max:
    lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:10f9 class-ID: 0403
  API: ALSA v: k6.6.1-zen1-1-zen
    status: kernel-api with: aoss
    type: oss-emulator
  Server-1: PipeWire v: 0.3.85
    status: n/a (root, process) with:
    1: pipewire-pulse status: active
    2: wireplumber status: active
    3: pipewire-alsa type: plugin 4: pw-jack
    type: plugin
  Device-1: Intel Comet Lake PCH CNVi WiFi
    driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:06f0 class-ID: 0280
  Device-2: Realtek RTL8111/8168/8411 PCI
    Express Gigabit Ethernet vendor: ASUSTeK
    driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000
    bus-ID: 03:00.0 chip-ID: 10ec:8168
  IF-ID-1: br-c63e71283689 state: down
    mac: <filter>
  IF-ID-2: docker0 state: down
    mac: <filter>
  Device-1: Intel AX201 Bluetooth
    driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1
    bus-ID: 1-14:6 chip-ID: 8087:0026
  Report: btmgmt ID: hci0 rfk-id: 0
    state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: no
    pairing: no class-ID: 7c010c
  Local Storage: total: 953.87 GiB
    used: 69.62 GiB (7.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0
    vendor: Intel model: SSDPEKNW010T8
    size: 953.87 GiB block-size:
    physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 tech: SSD
    serial: <filter> fw-rev: 002C
    temp: 30.9 C scheme: GPT
  SMART: yes health: PASSED
    on: 1y 218d 23h cycles: 559
    read-units: 42,419,744 [21.7 TB]
    written-units: 54,252,413 [27.7 TB]
  ID-1: / raw-size: 146.48 GiB
    size: 146.48 GiB (100.00%)
    used: 69.58 GiB (47.5%) fs: btrfs
    block-size: 4096 B dev: /dev/nvme0n1p6
    maj-min: 259:6
  ID-2: /boot/efi raw-size: 500 MiB
    size: 499.7 MiB (99.95%)
    used: 45.5 MiB (9.1%) fs: vfat
    block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  ID-3: /home raw-size: 146.48 GiB
    maj-min: 259:6
  ID-4: /var/log raw-size: 146.48 GiB
    maj-min: 259:6
  ID-5: /var/tmp raw-size: 146.48 GiB
    maj-min: 259:6
  Kernel: swappiness: 133 (default 60)
    cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: zram size: 31.14 GiB
    used: 0 KiB (0.0%) priority: 100
    comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842
  System Temperatures: cpu: 55.0 C
    pch: 48.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 3700
  Processes: 339 Uptime: 22m wakeups: 0
  Memory: total: 32 GiB available: 31.14 GiB
  used: 6.2 GiB (19.9%) igpu: 64 MiB
  Init: systemd v: 254 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1
  clang: 16.0.6 Packages: 1693 pm: pacman
  pkgs: 1686 libs: 455
  tools: gnome-software,octopi,paru pm: snap
  pkgs: 7 Shell: garuda-inxi (sudo)
  default: Bash v: 5.2.15 running-in: codium
  inxi: 3.3.31
Garuda (2.6.19-2):
  System install date:     2023-03-25
  Last full system update: 2023-12-02
  Windows dual boot:       Yes
Currently, I will try a System Update… I’ll see if this will help…
Edit: No… this does not help…
