Keyboard not functioning after system updating, Please help
root=UUID=013a0e6f-1e15-4ec6-8862-4c62cb69ca18 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 info: latte-dock
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3202
date: 06/15/2023
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3292 high: 4212 min/max: 400/4464 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3854 2: 3793 3: 3867
4: 3887 5: 4212 6: 3787 7: 3827 8: 400 9: 3860 10: 400 11: 3882 12: 3745
bogomips: 93426
built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
chip-ID: 1002:67df class-ID: 0300 temp: 72.0 C
Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 046d:0825
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: SCEI MONITOR serial: <filter>
built: 2011 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 522x294mm (20.55x11.57") diag: 600mm (23.6") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 480 Graphics
(polaris10 LLVM 16.0.6 DRM 3.54 6.5.9-zen2-1-zen) device-ID: 1002:67df
memory: 7.81 GiB unified: no
API: Vulkan v: 1.3.269 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 480 Graphics (RADV POLARIS10) driver: mesa radv
v: 23.2.1-arch1.2 device-ID: 1002:67df surfaces: xcb,xlib device: 1
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3
Device-4: Logitech [G533 Wireless Headset Dongle]
lanes: 1 mode: 1.1 bus-ID: 1-7.1:7 chip-ID: 046d:0a66 class-ID: 0300
Device-5: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:8 chip-ID: 8087:0029
Local Storage: total: 1.36 TiB used: 405.04 GiB (29.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 043 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500MX500SSD1
used: 405.04 GiB (87.0%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 1.2 MiB (0.4%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.41 GiB used: 8.5 MiB (0.1%) priority: 100
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 72.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 767
Processes: 336 Uptime: 17m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.41 GiB used: 4.09 GiB (26.6%) Init: systemd v: 254
Packages: 2132 pm: pacman pkgs: 2129 libs: 579 tools: octopi,pamac,paru,yay
pm: snap pkgs: 3 Shell: fish v: 3.6.1 default: Bash v: 5.2.15
Garuda (2.6.17-1):
System install date:     2023-11-01
Last full system update: 2023-11-08
Is partially upgraded:   Yes
Failed units:            nmb.service
What kind of keyboard is it?
Please post the full input and output of:
garuda-update
It is an old Logitech g510s I appreciate your fast response . I asked before if there’s a difference between update and garuda-update and they said there was no difference. I’m not sure how I had a partial upgrade. I had to pair down the terminal results because it said I was using to many characters. I hope I’m not posting to many results, but here goes.
╭─markf@mark1 in ~
╰─λ garuda-update
[sudo] password for markf:
garuda                                 97.5 KiB   121 KiB/s 00:01 [------------------------------------] 100%
core is up to date
extra is up to date
multilib is up to date
chaotic-aur                             2.6 MiB  2.81 MiB/s 00:01 [------------------------------------] 100%
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
warning: kde-servicemenus-pdf-encrypt-decrypt: local (1-1.4) is newer than chaotic-aur (1-1)
:: Replace libkcddb with extra/libkcddb5? [Y/n] y
:: Replace mhwd-db-garuda-git with garuda/mhwd-db-garuda? [Y/n] y
warning: performance-tweaks: local (2.1.2-3) is newer than garuda (2.1.2-1)
warning: reshade-shaders-git: local (r909.2459c73-1) is newer than chaotic-aur (r33.9e9fa9e-1)
resolving dependencies...
Packages (271) akonadi-23.08.3-1  akonadi-calendar-23.08.3-1  akonadi-contacts-23.08.3-1
akonadi-mime-23.08.3-1  akonadi-notes-23.08.3-1  akonadi-search-23.08.3-1
alsa-card-profiles-1:0.3.85-1  appstream-0.16.4-1  appstream-qt-0.16.4-1  ark-23.08.3-1
attica5-5.112.0-1  baloo-widgets-23.08.3-1  baloo5-5.112.0-1  bind-9.18.20-1
bluez-qt5-5.112.0-1  box2d-2.4.1-2  breeze-icons-5.112.0-1  btrfs-progs-6.6.1-1
chromium-119.0.6045.159-1  colord-kde-23.08.3-1  deepin-anything-arch-6.1.2-32
deepin-file-manager-1:6.0.34-1  deepin-image-editor-1.0.37-1  deepin-util-dfm-1.2.17-1
discord-0.0.35-1  discover-5.27.9-2  dolphin-23.08.3-1  dolphin-plugins-23.08.3-2
drkonqi-5.27.9-2  eza-0.16.0-1  ffmpegthumbs-23.08.3-1  filelight-23.08.3-1  firefox-119.0.1-1
frameworkintegration5-5.112.0-1  fwupd-1.9.8-1  garuda-boot-options-1.0.4-1
garuda-common-settings-2.6.19-2  garuda-network-assistant-1.1.3-1
garuda-video-linux-config-2:1.1.5-2  garuda-welcome-1.2.9-1  google-chrome-119.0.6045.159-1
grantleetheme-23.08.3-1  gst-libav-1.22.7-1  gst-plugin-pipewire-1:0.3.85-1
gst-plugins-bad-1.22.7-1  gst-plugins-bad-libs-1.22.7-1  gst-plugins-base-1.22.7-1
gst-plugins-base-libs-1.22.7-1  gst-plugins-good-1.22.7-1  gst-plugins-ugly-1.22.7-1
gstreamer-1.22.7-1  gstreamer-vaapi-1.22.7-1  gwenview-23.08.3-1  harfbuzz-8.3.0-1
harfbuzz-icu-8.3.0-1  hwdata-0.376-1  k3b-1:23.08.3-2  kaccounts-integration-23.08.3-1
kaccounts-providers-23.08.3-1  kactivities-stats5-5.112.0-1  kactivities5-5.112.0-1
kamera-23.08.3-1  karchive5-5.112.0-1  kate-23.08.3-1  kauth5-5.112.0-1  kbookmarks5-5.112.0-1
kcalc-23.08.3-1  kcalendarcore5-5.112.0-1  kcalutils-23.08.3-1  kclock-23.08.3-1
kcmutils5-5.112.0-1  kcodecs5-5.112.0-1  kcompletion5-5.112.0-1  kconfig5-5.112.0-1
kconfigwidgets5-5.112.0-1  kcontacts5-5.112.0-1  kcoreaddons5-5.112.0-1  kcrash5-5.112.0-1
kcron-23.08.3-1  kdav5-1:5.112.0-1  kdbusaddons5-5.112.0-1  kde-dev-scripts-23.08.3-1
kdeclarative5-5.112.0-1  kdeconnect-23.08.3-1  kded5-5.112.0-1
kdegraphics-mobipocket-23.08.3-1  kdegraphics-thumbnailers-23.08.3-1
kdelibs4support-5.112.0-1  kdenetwork-filesharing-23.08.3-1  kdepim-runtime-23.08.3-1
kdesu5-5.112.0-1  kdf-23.08.3-1  kdialog-23.08.3-1  kdnssd5-5.112.0-1  kdoctools5-5.112.0-1
keditbookmarks-23.08.3-1  kemoticons-5.112.0-1  kfilemetadata5-5.112.0-1  kfind-23.08.3-1
kget-23.08.3-1  kglobalaccel5-5.112.0-1  kguiaddons5-5.112.0-1  khelpcenter-23.08.3-1
kholidays5-1:5.112.0-1  khtml-5.112.0-1  ki18n5-5.112.0-1  kiconthemes5-5.112.0-1
kidentitymanagement-23.08.3-1  kidletime5-5.112.0-1  kimageformats5-5.112.0-1  kimap-23.08.3-1
kinit-5.112.0-1  kio-extras-23.08.3-1  kio-gdrive-23.08.3-1  kio5-5.112.0-1
kirigami2-5.112.0-1  kitemmodels5-5.112.0-1  kitemviews5-5.112.0-1  kjobwidgets5-5.112.0-1
kjs-5.112.0-1  kldap-23.08.3-1  kleopatra-23.08.3-1  kmailtransport-23.08.3-1  kmbox-23.08.3-1
kmime-23.08.3-1  knewstuff5-5.112.0-1  knotifications5-5.112.0-1  knotifyconfig5-5.112.0-1
kompare-23.08.3-1  konsole-23.08.3-1  kontactinterface-23.08.3-1  kpackage5-5.112.0-1
kparts5-5.112.0-1  kpeople5-5.112.0-1  kpimtextedit-23.08.3-1  kplotting5-5.112.0-1
kpmcore-23.08.3-1  kpty5-5.112.0-1  kqtquickcharts-23.08.3-1  kquickcharts5-5.112.0-1
krdc-23.08.3-1  krfb-23.08.3-1  kross-5.112.0-1  krunner5-5.112.0-1  ksanecore-23.08.3-1
kservice5-5.112.0-1  ksmtp-23.08.3-1  ksystemlog-23.08.3-1  ktexteditor5-5.112.0-1
ktextwidgets5-5.112.0-1  ktorrent-23.08.3-1  kunitconversion5-5.112.0-1
kuserfeedback5-1.3.0-4  kwallet5-5.112.0-1  kwalletmanager-23.08.3-1  kwayland5-5.112.0-1
kwidgetsaddons5-5.112.0-1  kwindowsystem5-5.112.0-1  kxmlgui5-5.112.0-1
lib32-harfbuzz-8.3.0-1  lib32-libelf-0.190-1  lib32-libpipewire-1:0.3.85-1
lib32-pipewire-1:0.3.85-1  lib32-pipewire-jack-1:0.3.85-1  lib32-systemd-254.6-1
libakonadi-23.08.3-1  libcap-2.69-2  libcloudproviders-0.3.5-1  libelf-0.190-1
libgravatar-23.08.3-1  libimagequant-4.2.2-2  libkcddb-23.08.2-1 [removal]
libkcddb5-23.08.3-4  libkdcraw-23.08.3-1  libkdepim-23.08.3-1  libkexiv2-23.08.3-1
libkgapi-23.08.3-1  libkleo-23.08.3-1  libkolabxml-1.2.1-4  libkomparediff2-23.08.3-1
libksane-23.08.3-1  libktorrent-23.08.3-1  libmaxminddb-1.8.0-1  liborcus-0.19.2-1
libpackagekit-glib-1.2.8-1  libpipewire-1:0.3.85-1  linux-6.6.1.arch1-1
linux-wifi-hotspot-4.6.0-1  linux-zen-6.6.1.zen1-1  linux-zen-headers-6.6.1.zen1-1
luajit-2.1.1700008891-1  mariadb-11.1.3-1  mariadb-clients-11.1.3-1  mariadb-libs-11.1.3-1
messagelib-23.08.3-1  mhwd-db-garuda-2:1.1.5-2  mhwd-db-garuda-git-1:r63.2f652e8-3 [removal]
modemmanager-qt5-5.112.0-1  mumble-1.5.517-6  mumble-server-1.5.517-6
networkmanager-qt5-5.112.0-1  npm-10.2.4-1  obs-studio-30.0.0-1  okular-23.08.3-1
packagekit-1.2.8-1  partitionmanager-23.08.3-1  patool-2.0.0-1  perl-io-socket-ssl-2.084-1
pimcommon-23.08.3-1  pipewire-1:0.3.85-1  pipewire-alsa-1:0.3.85-1  pipewire-audio-1:0.3.85-1
pipewire-jack-1:0.3.85-1  pipewire-pulse-1:0.3.85-1  pipewire-v4l2-1:0.3.85-1
pipewire-x11-bell-1:0.3.85-1  pipewire-zeroconf-1:0.3.85-1  plasma-framework5-5.112.0-1
plasma-wayland-protocols-1.11.1-1  plasma-workspace-5.27.9.1-2
plasma5-themes-sweet-full-git-r344.be36521-1  poco-1.12.5p1-1  print-manager-23.08.3-1
prison5-5.112.0-1  protontricks-git-1.10.5.r11.g68f965f-1  purpose5-5.112.0-1
python-cycler-0.12.1-1  python-fonttools-4.44.3-1  python-pillow-10.1.0-2
python-platformdirs-4.0.0-1  python-trove-classifiers-2023.11.9-1
qqc2-desktop-style5-5.112.0-1  qt5-base-5.15.11+kde+r146-1  qt5-declarative-5.15.11+kde+r32-1
qt5-tools-5.15.11+kde+r4-1  rate-mirrors-0.17.0-1
retroarch-autoconfig-udev-git-r2192.830f79f-1  scrcpy-2.2-1  serf-1.3.10-1  sfml-2.6.1-1
shared-mime-info-2.4-1  signon-kwallet-extension-23.08.3-1  skanlite-23.08.3-1
sof-firmware-2023.09.2-1  solid5-5.112.0-1  sonnet5-5.112.0-1  spdlog-1.12.0-2
spectacle-23.08.3-1  sudo-1.9.15.p2-1  syndication5-5.112.0-1  syntax-highlighting5-5.112.0-1
systemd-254.6-2  systemd-libs-254.6-2  systemd-sysvcompat-254.6-2  telegram-desktop-4.11.8-1
threadweaver5-5.112.0-1  thunderbird-115.4.3-1  ugrep-4.3.3-1  visual-studio-code-bin-1.84.2-1
vivaldi-6.4.3160.42-1  webkit2gtk-2.42.2-1  webkit2gtk-4.1-2.42.2-1  whois-5.5.20-1
wine-staging-8.20-1  wxwidgets-common-3.2.4-1  wxwidgets-gtk3-3.2.4-1
xdg-desktop-portal-1.18.1-1  yakuake-23.08.3-1  yay-git-12.1.3.r5.g8f98ab3-1
zanshin-23.08.3-1  zeroc-ice-3.7.10-1
Total Download Size:      0.36 MiB
Total Installed Size:  4820.99 MiB
Net Upgrade Size:        10.31 MiB
Also, I searched for about an hour on the web, and the Arch forums, and it said I need to revert back to a previous kernel, which I’m not sure how to do.
Try switching to the LTS kernel, which is on version 6.1.
You can choose an alternate kernel from the advanced boot options in the Grub menu.
Thanks so much Blue! I was looking for version #s for the kernels on the advanced boot options and didn’t see the lts one. Sweet!
