i use the colemak keyboard layout and i recently reinstalled garuda on my desktop, after the reinstall most applications such as firefox seem to read it as a basic US qwerty layout. However gnome shortcuts and some apps such as the terminal and nautilus seem to behave correctly.
in addition to this, for some reason when i hold down certain characters such as "o" for example, it functions like a "alternate characters key", so pressing "n" whilst holding it down spits out "ñ". This makes wo`ds such as functioñ rather painful to write.
I tried looking thru this issue, but nothing seemed to work:
this is my /etc/vconsole.conf file:
FONT=ter-220n
KEYMAP=colemak
XKBLAYOUT=us
XKBVARIANT=colemak
The only temporary fix i've found for this is to add a new keyboard layout, switch to it and switch back. It cannot be a keyboard layout used previously, it doesn't fix the accent problem, and it only lasts until next boot.
Does anyone know why this is happening, or if they have any more permanent solutions?
garuda-inxi:
Kernel: 6.2.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=d3bcb30e-718f-4bfa-9211-08fed10254e0 rw [email protected]
resume=UUID=76ef5072-e3cc-411f-a27d-2f02016dcfee loglevel=3 ibt=off
Desktop: GNOME v: 43.4 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.0
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 4007
date: 12/08/2020
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: N/A
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3712 high: 3800 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3597 2: 3800
3: 3603 4: 3602 5: 3599 6: 3800 7: 3800 8: 3598 9: 3602 10: 3800 11: 3601
12: 3800 13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121608
vendor: XFX Speedster QICK 319 driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2,DP-3 empty: HDMI-A-1
bus-ID: 0b:00.0 chip-ID: 1002:73df class-ID: 0300
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: AOC 24G1WG4 serial: <filter> built: 2018
res: 1920x1080 dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54")
diag: 598mm (23.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: DP-2 model: AOC 27G2G4 serial: <filter> built: 2021
res: 1920x1080 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-3: DP-3 model: AOC 2460G5 serial: <filter> built: 2016
res: 1920x1080 dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: AMD Radeon RX 6700 XT (navi22
LLVM 15.0.7 DRM 3.49 6.2.10-zen1-1-zen) direct-render: Yes
bus-ID: 1-5.3:4 chip-ID: 046d:0ab5 gen: 4 class-ID: 0300 speed: 16 GT/s
lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28 class-ID: 0403
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech G733 Gaming Headset type: USB
API: ALSA v: k6.2.10-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
Local Storage: total: 1.03 TiB used: 497.37 GiB (47.3%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
rev: 211070WD temp: 34.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD6SB1M128G1001
type: SSD serial: <filter> rev: 201 scheme: MBR
ID-1: / raw-size: 897.11 GiB size: 897.11 GiB (100.00%)
used: 497.37 GiB (55.4%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 897.11 GiB size: 897.11 GiB (100.00%)
ID-3: /var/log raw-size: 897.11 GiB size: 897.11 GiB (100.00%)
ID-4: /var/tmp raw-size: 897.11 GiB size: 897.11 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.54 GiB used: 1.5 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.4 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 43.0 C mobo: 32.0 C gpu: amdgpu temp: 37.0 C
mem: 34.0 C
Fan Speeds (RPM): cpu: 675 case-1: 837 case-2: 862 case-3: 967 gpu: amdgpu
fan: 0
Power: 12v: 10.14 5v: N/A 3.3v: N/A vbat: 3.21 gpu: amdgpu watts: 6.00
Processes: 412 Uptime: 10m wakeups: 0 Memory: 15.55 GiB
used: 5.01 GiB (32.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1603
libs: 495 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.26
System install date: 2023-04-11
Last full system update: 2023-04-12
