Hi ,
i have somehow crashed my garuda just this day , lukily i had a booted pendrive for garuda and now i have reinstalled garuda soaring version . I know it is old so i was updating it but there were some conflicting dependencies , well i am good in playing with this issue but the main issue is there is some keyring problem , whenever i try to install something it shows me this:
╭─ankur at ankur-inspiron7570 in ⌁
╰─λ sudo pacman -Sy ananicy-git
[sudo] password for ankur:
error: failed retrieving file 'core.db' from mirror.pseudoform.org : Protocol "rsync" not supported or disabled in libcurl
core is up to date
error: failed retrieving file 'extra.db' from mirror.pseudoform.org : Protocol "rsync" not supported or disabled in libcurl
extra is up to date
error: failed retrieving file 'community.db' from mirror.pseudoform.org : Protocol "rsync" not supported or disabled in libcurl
community is up to date
error: failed retrieving file 'multilib.db' from mirror.pseudoform.org : Protocol "rsync" not supported or disabled in libcurl
multilib is up to date
chaotic-aur 1548.5 KiB 238 KiB/s 00:07 [----------------------------] 100%
resolving dependencies...
Packages (1) ananicy-git-2.2.1.r60.g0b06948-1
Total Installed Size: 0.09 MiB
Net Upgrade Size: 0.03 MiB
(1/1) checking keys in keyring [----------------------------] 100%
downloading required keys...
:: Import PGP key 0706B90D37D9B881, "Nico Jensch <[email protected]>"? [Y/n] y
error: key "0706B90D37D9B881" could not be looked up remotely
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
╰─λ
please help me i have some urgent things do at this time, but cat do without updating.....
Thanks, in advance.
inxi -Fxxxz
╰─λ inxi -Fxxxz
Kernel: 5.10.4-107-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Type: Laptop System: Dell product: Inspiron 7570 v: N/A serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Dell model: 06K08K v: A00 serial: <filter> UEFI: Dell v: 1.16.0
date: 02/17/2020
ID-1: BAT0 charge: 18.3 Wh condition: 18.3/42.0 Wh (44%) volts: 12.7/11.4
model: Samsung SDI DELL CYMGM79 type: Li-ion serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake
note: check rev: A L2 cache: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 32026
Speed: 4001 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 4001 2: 3950 3: 3898
4: 3838 5: 4002 6: 4005 7: 3900 8: 3907
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5917
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Dell driver: nvidia v: 460.27.04
bus ID: 01:00.0 chip ID: 10de:134d
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-5:4 chip ID: 1bcf:28c1
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.2
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.10.4-107-tkg-bmq
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell
driver: r8169 v: kernel port: d000 bus ID: 02:00.0 chip ID: 10ec:8168
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: d000 bus ID: 03:00.0
chip ID: 8086:095a
IF-ID-1: enp0s20f0u1 state: unknown speed: N/A duplex: N/A mac: <filter>
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0
port: f060 bus ID: 00:17.0 chip ID: 8086.282a rev: 21
Local Storage: total: 1.14 TiB used: 7.27 GiB (0.6%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
speed: 6.0 Gb/s serial: <filter> rev: SDM3
ID-2: /dev/sdb vendor: Micron model: 1100 SATA 256GB size: 238.47 GiB
speed: 6.0 Gb/s serial: <filter> rev: L003
ID-1: / size: 931.22 GiB used: 7.27 GiB (0.8%) fs: btrfs dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 560 KiB (0.2%) fs: vfat dev: /dev/sda1
ID-3: /home size: 931.22 GiB used: 7.27 GiB (0.8%) fs: btrfs dev: /dev/sda2
ID-4: /var/log size: 931.22 GiB used: 7.27 GiB (0.8%) fs: btrfs dev: /dev/sda2
ID-5: /var/tmp size: 931.22 GiB used: 7.27 GiB (0.8%) fs: btrfs dev: /dev/sda2
ID-1: swap-1 type: zram size: 961.8 MiB used: 0 KiB (0.0%) priority: 32767
ID-2: swap-2 type: zram size: 961.8 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 961.8 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 961.8 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-5: swap-5 type: zram size: 961.8 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-6: swap-6 type: zram size: 961.8 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
ID-7: swap-7 type: zram size: 961.8 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram6
ID-8: swap-8 type: zram size: 961.8 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram7
System Temperatures: cpu: 52.0 C mobo: 50.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 2565
Processes: 259 Uptime: 36m wakeups: 4 Memory: 7.51 GiB used: 3.25 GiB (43.2%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1164 Shell: fish
v: 3.1.2 running in: alacritty inxi: 3.2.01
╰─λ
