hi tnx to you i got anbox working but the kernel moduel wont mount on boot can you help me with that tnx in advance:)
Could you post your terminal output of this:
sudo ls -1 /dev/{ashmem,binderfs}
Which kernel are you using?
tnx for replying im using xanmod kernel and the output is
/dev/ashmem
/dev/binderfs:
binder
binder1
binder-control
features
hwbinder
vndbinder
when i boot it shows me this error message saying failed to mount biinderfs. but when i manually mount it it works.
I hope you have entered everything correctly into fstab & /etc/tmpfiles.d/anbox.conf ?
Please recheck your steps.
Rest I don't see any problem causing it.
ok did i do something wrong in the fastab config here is what it looks like.
this is the fastab one
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=43edd5f2-593f-456b-90a1-1c6296c22c73 swap swap defaults,noati>
UUID=362C-479D /boot/efi vfat umask=0077 0 2
UUID=a9580fab-06f1-42bc-8c6e-8ed3c2caad41 / ext4 defaults,noati>
/etc/fstab
none /dev/binderfs binder nofail 0 0
d! /dev/binderfs 0755 root root
this is the /etc/tmpfiles.d/anbox.conf one did i do some thing wrong
Yes, you post a picture from a text file.
fixed it XD i just it wouldnt let me select every thing interminal XD
Remove the #
it make text big
or just use the preformatted text with ~~~ in first and last line, terminal output between.
Would you mind formatting your reply correctly?
Format all terminal output as preformatted text (or select text and press ctrl + E ), as SGS has pointed out.
Rest, from what I can understand, things seem to be okay.
Edit: Also, would you post the output of sudo mount -a
after a reboot without mounting binder.
It's getting late in India, I will be able to help tomorrow only now
ok tnx im new so i dont know this things
ow sry it was late where i live then so i didnt se this but canu still be able to help me here is the out put.mount:
mount: /etc/fstab: parse error at line 11 -- ignored
mount: /dev/binderfs: must be superuser to use mount.
Why do you use ext4?
Please post your inxi -Faz
Hello.
inxi -Faz
Wrong forum, I think
huh how am i so dumb pls forgive me
ok here is the out put of inxi -faz
Kernel: 5.15.6-xanmod2-2 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-xanmod-anbox
root=UUID=a9580fab-06f1-42bc-8c6e-8ed3c2caad41 rw quiet
resume=UUID=43edd5f2-593f-456b-90a1-1c6296c22c73 udev.log_priority=3
zswap.enabled=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel, plank
wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Dell product: Inspiron 3185 v: 1.2.0
serial: <superuser required> Chassis: type: 10 v: 1.2.0
Mobo: Dell model: 0T60DD v: A00 serial: <superuser required> UEFI: Dell
v: 1.2.0 date: 02/09/2018
ID-1: BAT0 charge: 11.6 Wh (61.1%) condition: 19.0/32.0 Wh (59.3%)
volts: 7.6 min: 7.6 model: Samsung SDI DELL PGYK582 type: Li-ion
Info: Dual Core model: AMD A9-9420e RADEON R5 5 COMPUTE CORES 2C+3G
bits: 64 type: MCP arch: Excavator family: 15 (21) model-id: 70 (112)
stepping: 0 microcode: 6006704 cache: L1: 256 KiB L2: 2 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 7186
Speed: 2605 MHz min/max: 1200/1800 MHz boost: enabled Core speeds (MHz):
1: 2695 2: 2695
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Dell
driver: amdgpu v: kernel bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-1.1:3 chip-ID: 0c45:671f class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: xfwm4 v: 4.16.1 driver:
display-ID: :0.0 screens: 1
s-diag: 414mm (16.3")
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 136 size: 256x144mm (10.1x5.7")
diag: 294mm (11.6")
OpenGL: renderer: AMD STONEY (DRM 3.42.0 5.15.6-xanmod2-2 LLVM 13.0.0)
v: 4.5 Mesa 21.2.5 direct render: Yes
Device-1: AMD vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:01.1
chip-ID: 1002:15b3 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
Sound Server-1: ALSA v: k5.15.6-xanmod2-2 running: yes
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell Vostro 3470 driver: ath9k v: kernel bus-ID: 01:00.0
chip-ID: 168c:0036 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 2-2:4
chip-ID: 0cf3:e005 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends
Local Storage: total: 465.76 GiB used: 298.18 GiB (64.0%)
model: WD5000LPCX-75VHAT1 size: 465.76 GiB block-size: physical: 4096 B
rev: 1A05 scheme: GPT
ID-1: / raw-size: 420.21 GiB size: 412.54 GiB (98.18%)
used: 298.18 GiB (72.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 515 MiB size: 514 MiB (99.80%)
used: 304 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
Kernel: swappiness: 30 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 4.98 GiB used: 1 MiB (0.0%)
priority: -2 dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 38.0 C mobo: 44.0 C sodimm: SODIMM C gpu: amdgpu
temp: 38.0 C
Processes: 216 Uptime: 38m wakeups: 1 Memory: 3.72 GiB
used: 2.27 GiB (61.0%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1687 pacman: 1667 lib: 500 flatpak: 10 snap: 10
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: xfce4-terminal
inxi: 3.3.09
and itried solving it by trying diffrent kernels with different versions i also tried to install anbox-modules-dkms but trying to install that it just gives me an eror it holds the anbox moduels binder and ashmem but it wont install so i refered to this article then after following each steps it worked for me but after a reboot it gives me an eror during the rebbot saying failed to mount binderfs then anbox stopped working after the reboot i also had problems with running and installing snap packages but reinstalling it it worked but it still gives out this eror when irun snap apps woth therminal.
2021/12/14 09:52:55.782572 system_key.go:129: cannot determine nfs usage in generateSystemKey: cannot parse /etc/fstab: expected between 3 and 6 fields, found 1
but the snap apps luanch properly work also when i run anbox system-info it shows that binder isnt present
version: local-84f0268
cpu:
arch: x86
brand: AMD A9-9420e RADEON R5, 5 COMPUTE CORES 2C+3G
features:
- aes
- sse4_1
- sse4_2
- avx
- avx2
os:
version:
snap-based: false
kernel:
version: Linux version 5.15.6-xanmod2-2 (makepkg@archlinux) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP Wed, 08 Dec 2021 19:46:46 +0000
binder: false
binderfs: true
ashmem: true
hope i covered every thing im still very new to Linux so pls dont blame me if ido something stupid like posting pic XD tnx for your help <3.
No.
yah just leave it at this point i will just accept anbox dosent work for me tnx for all you guys help and sry for your troubles.
Didn't you use sudo?
BTW you could install Garuda Linux and then try installing anbox?
I am not being persuasive. But I too switched to Garuda from Manjaro and I didn't regret it!
ya i know garuda is hands down one of the best distro i ever tried every thing is pre installed wine is pre configured its so beautiful also it has a great community . i was using the gaming edition one but my potato pc couldnt handle it things kept crashing b/c of ram shortage and youtube buffer was insanely high at boot it used up 2gb of ram and i dont have a good pc its preety low end 4gb ram coreI2 and 80mb of vram so i had to remove it i tied the lxqt one but it also used 1.6gb of ram on boot.but even in the gaming edition one games run very smoothly even with
high ram usage.
But i started using linux full time b/c of garuda linux i saw how beautiful it is and how well it run windows apps and games. but i had to go with a light weight distro like manjaro xfce.
Your topic is confusing. "Manjaro"?? This is the support forum for Garuda
