Kernel changing
Hi. How can i change kernel in system ?
By installing the desired kernel and selecting it in the grub menu after a reboot. If you want to add the kernel permanently, then open “Garuda Boot Options” and select it as default.
Please post your garuda-inxi as requested by the template.
And you can install a kernel with either
Garuda Settings Manager → Kernel (remember to push Refresh button first)
or from terminal simply with e.g.
Thank you
Thank you too
